0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 Head gaskets.
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 27th April 2008
flskevin's Avatar
flskevin flskevin is offline
Be annoyed Now;Ask Me How
Sportster/Buell Model: 1200XL Custom
Other Motorcycle Model: FLSTC Heritage Softail
Other Motorcycle Year: 2008
flskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant future
Default Unique Speedo Problem
So last thursday morning my speedometer decided to stop working. But it's a little peculiar...
The unit is getting power. The backlight is working, the odometer comes on. The speedo needle jumps up like normal. But when I go forward, nothing. The odometer won't count miles either.
Usually it's a loose plug under the seat. But that kills the power to the entire unit. I checked all the plugs & connections and everything seems fine.
I'm guessing that it's a loose wire from the sending unit or maybe a bad sending unit.
Any suggestions?
BTW - One other small but maybe unrelated problem is that my rear turn signals won't auto turn off when I make a turn. (I have a load equalizer on my bike to power the turn signals when I changed them) Is it possible the LE has gone bad and caused both problems?
I am going to take that out and see what happens.
"... With Liberty & Justice for All." Must be 18, Void where prohibited, Some restrictions may apply, Not available in all 50 states.
Pastafarian Minister - Church of the Flying Spaghetti Monster
Dudeist Priest - Church of the Latter Day Dude
Old 27th April 2008
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Time to check for loose ground........... and dirty or faulty speed sensor down by starter and left of front drive pulley??
RTFS
Ride That F'N Sportster!!
Old 3rd May 2008
flskevin's Avatar
Just to update...
After researching the problem I first cleaned the speed sensor to see if that would fix the problem. It didn't but before I replaced it I checked all my wires & connections.
Everything tested okay all my fuses were still good so I decided to get a new sensor. $55 later I installed the new sensor and the speedo is working again.
I think one of the causes for it's demise was using HD syn3 in the primary. Since the sensor works by being magnetic it had some metal flakes off the gears and messed it up over time.
After some more research I decided to switch to Mobil 1 syn 75/90 gear oil and see if it shifts and runs smoother.
Old 3rd May 2008
Phaedrus's Avatar
Phaedrus Phaedrus is offline
Speed Sensor
Old 3rd May 2008
xllent01's Avatar
Those sensors are magnetic for a reason..........it was prolly on it's way out regaurdless of what oil you run....... those little parts do fail.....
even on a 8-9 yr old bike........... glad you fixed the problem!!
Old 3rd May 2008
Horse's Avatar
Horse Horse is offline
Sportster/Buell Model #2: XLH 883/1200
Sportster/Buell Year #2: 1995
Other Motorcycle Model: FXDBI
Other Motorcycle Year: 06
Horse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to behold
I think running gear oil in your primary is a mistake. I'm not a big fan of most HD fluids, but their primary oil is pretty decent stuff.
R.I.P. Brother
Mocha Mafioso
Old 3rd May 2008
flskevin's Avatar
I have done a lot of research on this before I made my decision.
Besides how can it be a mistake to switch out oil that is made for the motor/primary for an extra high performance oil designed for a specific purpose?
My experience using HD sny 3 has not been too good. It was time to find something better.
