0 1972 tank fitment
0 bike went for a slide
0 New England 2018
Last Post: The Crusher
0 90 in. Build
Last Post: Jheitt
0 Help me with gas cap...
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: Screw Loose Dan
Last Post: dnaj11
Last Post: gravydog
Old 21st January 2006
pigdog pigdog is offline
Sportster/Buell Model #2: Softail Deluxe
Sportster/Buell Year #2: 06
Other Motorcycle Model: V-Rod NR
Other Motorcycle Year: 06
pigdog has disabled reputation
Default 412 install help
I read the how-to above on installing shocks. I bought the 12" 412's for my 05 1200c. I dont have a stand, but I have a sisscors jack. I took off the left side shock, and cant seem to jack it up so the shock will line up. How the heck do I get it to line up? Do I need to get a stand and or remove both shocks?
Carl-04XL's Avatar
Carl-04XL Carl-04XL is offline
Sportster/Buell Model: XL1200R 'Ms Lily'
Carl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the roughCarl-04XL is a jewel in the rough
Go to Northern, Sears or Pep Boys and get a atv/lawn tractor/motorcycle jack. I think Northern or Pep Boys are less expensive than Sears, but Sears has one that you can take the handle off for easier rightside access. Don't forget the tie-downs for security.
You will have to take both shocks off if the stockers are of different length than the 412's. You'll have to let the rear wheel lightly rest on the ground while you are lining up the mounting holes, or some way to raise/lower the wheel... A little 'finesse' is needed at times.
Carl
Which way to the egret!
