0 sportster revival
Last Post: Fivecats
Last Post: 73HEAD
0 71 XLH Value?
0 The Strociek Project
0 Trouble removing old license plate
0 Posting Pics
Last Post: BigAl57
7 2001 xlh 1200 off road
Last Post: Warlock
0 Allegheny National Park III
0 Hello From Brighton, England
9 Very long pullback handlebars required
Last Post: Elzer0
0 Japanese Cush Drive!!
0 Canadian Purchases
Last Post: XL Ed
0 Looking for community help/steering/front end issues
0 best set up for ease of kick starting
Last Post: The Doctor71
0 Front fender legalities in the UK
0 Oil coming out of top of cam cover
Last Post: Kingrabbit
bolts, cam, cam cover, ironhead 1975, sportster
Old 28th April 2019
Kennyv's Avatar
Kennyv Kennyv is offline
Sportster/Buell Model: xlh-1000
Kennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really niceKennyv is just really nice
Default 75 Ironhead cam cover - Screws don't fit missing bolt
Working on my 75 Sportster. Was missing the lower left cam cover bolt when I got it. Picture below shows the missing bolt. So I purchased this colony cam cover screw kit.
Colony-cam-cover-screw-kit J&P Cycles Part Number: 433-567
Manufacturer Part Number: 8783-8
I cannot find anywhere in the service manual bolt sizes for the cam cover. But none of the bolts from the kit fit that hole. They are too large and will not even go into the hole. I removed the bolt from the hole to the right of the missing one to see what size it was and it does not fit that hole either.
Whats up with this? Do I have a modified or non original cam cover or something? What do I need to replace this thing? See picture.
Old 28th April 2019
Kennyv's Avatar
Here is the picture of the missing bolt
Old 28th April 2019
doodah man's Avatar
it's been a while since i've had my cover off, but the bolt will be 1/4-20 and the parts book lists a few different lengths: 1 1/4", 1 3/4", and 2 1/4". i'd bet the 2 1/4" bolt is the one you need. you could also buy a good length of 1/4-20 threaded rod and screw it in five or six turns then mark and measure it and buy the appropriate length bolt. the threaded rod will come in handy again at some point for your bike, i'm sure.
Old 28th April 2019
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
Sorry I can't see the hole need better pic I guess or maybe new eyes..
I believe there is suppose to be a bolt just above the arow and it will be the same diameter as the others 1/4 x 20 is the standard thread for all of the cover bolts. If you have one smaller diam. you need to look closely and make sure it hasn't had the head drilled off of it to remove the cover . I have seen this a few times where a bolt is seized in the case and they left the bolt in the hole rather than trying to remove it from the case.
good luck let us know what you find.
. When told " That Won't Work "
I say " Hide And Watch. " :
Old 28th April 2019
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
if this is the place, its a standard case bolt 1/4 x 20 maybe the old one is broken and still in there
Old 28th April 2019
Kennyv's Avatar
Really appreciate all the help ... this forum is awesome, didn't expect such quick replies and nobody even gave me crap for asking a stupid question.
So I investigated closer this morning. Guess, my eyes are not as good as they used to be. There was a washer embedded into the hole. Little bit scary as to why the previous owner had the wrong size washer there and missing a bolt. I sure hope there is nothing broken off inside the cam case but I really don't want to open her up to see. If I do, I'm likely make things worse.
Anyway. take a look at this pic and you can see how easy it was to mistake it. That washer blends right in. That smaller hole to the left has a washer on it believe it or not. I took a 2.5" nail I had on hand and stuck it in the hole and it never even bottomed out. So I am going to try the 2 1/4" bolt. I believe the bolt to the right of that hole is the shorter 1 3/4".
Thanks for the quick help!! Now time to finish rebuilding my caliper, carb, new gas tank, rocker cover leak ... who knows what else. Really didn't know what I was getting myself into when I traded one of my guitars for this. Anyway, it is fun and rewarding.
Old 28th April 2019
Kennyv's Avatar
And here she is ... a work in progress.
Looks much better with the mustang style tank taken off of it.
Before with tank
Old 28th April 2019
doodah man's Avatar
So, what kind of guitar did the other guy get??
Old 29th April 2019
Kennyv's Avatar
The guitar was a Dillon acoustic electric. Worth about $250. Altogether, trade value was about $700. The bike sat for about 2 years. Threw it on a trailer, took it home, put some stabile in the tank, oil and charged the battery. It did fire up and run the next day. It idled real high for about 10 seconds then stalled. Sounded ok to me but I probably wouldn't know the difference unless something drastic was wrong. I left it for what it is since the carb is nasty and instead of messing around with it just started tearing it down.
Old 29th April 2019
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
That looks like a washer stuck in there.
