0 First start question
Last Post: Jaime1840
5 Rethinking 1250 Build
1 Buy your New iPhone 13/ 13 Mini/ 13 Pro/ 13 Pro Max in Bulk and good price
Last Post: sinikbab22
0 Exhaust question
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
Old 20th June 2019
Scott Scott is offline
Sportster/Buell Year: 1981
Sportster/Buell Model #2: Sportster with sidecar
Other Motorcycle Year: 2002
Default Cam cover ID help, please (warning - HUGE pics)
I removed the [IMG] codes to eliminate the trouble that comes with monster-sized photos. Please click on the links to see the photos. I haven't figured out how to navigate imgur yet.
Full disclosure - I need to sell this early cam cover to make room for more stuff I don't ned and want to be sure I provide as good a description as possible. Can anyone look past the huge photos and give me a range of years it will fit? The only numbers on it are "02-68"
https://i.imgur.com/SBEzU1r.jpg
https://i.imgur.com/Cce2iJO.jpg
https://i.imgur.com/OAk6wWc.jpg
Old 20th June 2019
Is that a Feb - 68 casting mark?
Old 20th June 2019
"02-68" is the only number on the cam cover. Does the casting number say anything about the range of model years it fits, or just when it was made?
Old 20th June 2019
It's tough to read the thread with the wide pics - so just post the link to them - not the pic itself...
Then use the pic I uploaded for you - use the jpg address below between the [IMG] tags to display this 800px image...
Here you go:
- Ironhead - Cam Cover
https://imgur.com/a/6r5qFSG
Old 20th June 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
To down size pics in imgur.com: in Images, click the pic, when it comes up, click "edit pic" in lower right corner. When that comes up there is a size in the upper right corner, change it to 1000-1100 and the right side size will auto change. Hit save. Then use your bbcode to copy and paste it into the message block at the bottom of the thread..... You can edit your posts by erasing the [img] 's and paste the new ones in it's place.
Old 20th June 2019
http://xlforum.net/forums/showpost.p...65&postcount=4
http://xlforum.net/forums/showthread.php?t=44736
A later parts book (post -70) may yield clues on years of fitment.
On the plus side, Americans are learning the Greek alphabet.
Old 20th June 2019
Thanks to all that replied - especially regarding the cursed huge imgur photos. The first link posted by GA Ironhead told me what I need to know. Thanks again.
Old 20th June 2019
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
1968-70 xlch
"Ride 'em, don't hide 'em!"
Old 21st June 2019
It may fit up through all the right side shifter years.
Would need early cams to use it on a cone motor.
Old 21st June 2019
doodah man's Avatar
+ '75 and '76 with a few additional mods.
