Last Post: clif02
0 TC Brothers weld on rigid on an early frame
0 Sidestand Extension/'Pad' ?
14 What made the best Improvement to your Sporty??
Last Post: wardie
0 switching from 16" to 18" rear tire
Last Post: wardie
0 Cobra fi2000 powrpro black
Last Post: RAIDER0372
0 Jiffy stand spring
0 Spokes or Mags
Last Post: d10221
0 Sissy bar and rack for 883
0 Burly Stilletto 13" shocks or ?
Last Post: Andy56
0 Changed The Fork Oil
0 Ironhead or Evo
Last Post: Andy Hog
0 is a buell a harley
Last Post: 84rzv500r
Last Post: wardie
0 HD announces end of the Sportster model
0 New guy
0 ‘72 Pinion gear question
0 When Were You Born?
0 ironhead oil pump pressure
  #51
Old 12th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
What I mean is if you chose open new map on your computer in the tc88 software and chose race and set initial 2 slope 0 you can see that table. I used it as a guide for my map in the low map/low rpm range. My switches are on 5/5.
Map is sent.
Old 12th July 2019
Riding with Angels
OK
I have NEVER used that function !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 13th July 2019
wedge's Avatar
wedge wedge is offline
FYI, here is exactly what I have in my HSR-42
180 main
723 Y8 Needle Jet
8DDY1 - 97 Needle
Clip second groove from top
27.5 pilot
3/4 turn mix
Old 13th July 2019
Riding with Angels
Thanks Pete !
Ill check my notes later and see whats in the 48 on the bike now
Close to Mat Hormels tune though
Old 13th July 2019
Riding with Angels
Heres what my notes say
27.5 pilot
185 main
97 needle,clip # 2
Y8 needle jet
#60 pump
Old 13th July 2019
60Gunner's Avatar
Damn, that's some juice, guys. Thanks.
I like the idea of the Y8 needle jet rather than the 96 needle 3rd clip.
3/4 turn with screw and 27.5 pilot? You must have the slide open pretty far then at idle?
M8ne starts to die at 1 1/4 turns out with the 25 but I cant get to slow turning it out. It just leans out and pops if I twist the throttle turned that far out.
This is interesting.
Nevermind. I think I've got it. You mean 2 3/4 on the screw. Don't worry about the 2 1/2 turns and go smaller thing.
Old 13th July 2019
60Gunner's Avatar
OK
It just allows you to see or start out with the timing tables of the switch positions. You can change the values and save it as a custom map then.
Old 13th July 2019
60Gunner's Avatar
0k, my pilot is good at 25. 1 1/2 turns on the screw. I could go with the 27 and might but not until I get the Y8 needle jet. It's either that or the 96 needle. The 27 pilot doesn't transition well with the 97 needle and Y6 needle jet.
The 170 main feels good. I doubt any bigger will help.
I'm sure I'll be in the upper 80s now with both HP and torque by 5500 rpm. My exhaust plays really well with my cams in the 3000 to 5500 rpm range. It makes some really good power there.
I'd say the 88 was a really good guess on the HP. What surprised me was the torque being that high as well and that early. It's a fun ass ride. How can you not like 88/88 by 5500?
Old 10th August 2019
60Gunner's Avatar
I just had a spur of the moment, impromptu dyno session. Stopped in as an afterthought when I happened to be driving by. Started talking to the tech that dyno'd me and one thing lead to another telling him about the crankcase breathers being bad that day and they agreed to do a pull or 2 for $40 just to see what if any improvement was there from running the krankvent after the failed umbrellas. I was running it in the cam chest first and replaced the breather bolts with solid bolts.
I did see a 4.5hp and just short of 2y6ft.lb. improvement on the first pull that I attribute to fixing the crankcase breathing as much as anything. I did go from a 165 main to a 170 and replaced the y6 needle jet with the y8 and lowered the 97 needle to the 2nd groove from the middle previously.
I was going to put the 165 main back in to test this theory when he discovered we broke the dyno.
Long story short, it wouldn't print but otherwise functioned as far as he could tell but his boss shut it down and I got a free pull out of the deal with a gift certificate to do a pull for $40 at a later date.
This time it continued to pull to 5500rpm where it leveled off but didn't drop. The torque climbed a little higher and hung on slightly longer before dropping off not as quickly.
Just short of 87hp and 89ft.lbs. of torque.
I added a dotted line to the old dyno to show what today's was since it wouldn't print. This is pretty close.
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
That's really an improvement! Crankvent wins!!
