0 Another question re: Microsquirt
Last Post: t120r
0 900 clutch in a 1000 engine Strociek
Last Post: thefrenchowl
0 Ironhead engine problem?
0 Showa 54000088 Shocks
Last Post: d10221
0 North central Mass
0 1100 bathtub heads on a 883?
Last Post: JimVonBaden
0 1968 ex barn dweller thread
Last Post: davixlrtt
0 Setting Timing, 1964 & Earlier Mag
0 XR1000 black and orange pics?
Last Post: 84rzv500r
0 my sunday driver...
0 XR1000 Pushrod Tube Leaks
Last Post: KRTTXRTT
0 1997 Air Cleaner Backplate
Last Post: rathawk
0 Dining out
0 Happy Thanksgiving
0 Strociek Project Help Needed
0 Which Sportster car costs about 2000$?
0 Allegheny National Park III
Last Post: sprink
Last Post: mikethebike61
excel50 (80), blazer95 (71), mycle1000, Barryn37 (60), QBALL (60), paulieb (59), cfranz (48), BMXATV (47), ravyn3 (42), Texas_Wild, hillpope (39)
Old 12th August 2019
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Default First startup
Hey all I just buttoned everything up on my 71 xlch...kicking it over w nothing but a xouple pops...I also had oil spit out my vent tube..is that just extra oil that's in there?I would imagine it would take a bit to kick over it ran when I bought it but just had it sit for a couple months while I did some work on it...nothing major in the motor or trans...new tank fender stuff like that..any tips on what to look for while trying to kick her over again ?
Sent from my LM-X210APM using Tapatalk
Originally Posted by mickey t View Post
...I also had oil spit out my vent tube..is that just extra oil that's in there?...
Yes, most likely
doodah man's Avatar
while it was sitting for a couple of months, did you keep the battery on a tender or get a new battery? if it's the old battery it could just be dead or not enough juice to light it off.
mickey t's Avatar
Well it wasn't on a constant tender...what I did was charge it to full charge..remoced it then charged to full charge again before I tried to kick it....if it shows full charge could it still ne weak to kick it over?
Wet sumped... All part of their charm.
http://xlforum.net/forums/showpost.p...8&postcount=40
Science doesn't care what you think.
To be good, a battery must satisfy all three conditions...
  • it must take a charge
  • it must hold the charge over time
  • it must hold the charge under load
So
  1. give it a full charge,
  2. disconnect the charger and let it sit for 24 hours,
  3. attach a voltmeter, watch the voltmeter while cranking the engine with the starter button. The reading should not drop below 10 or 11 [people have different opinions here] volts.
If you have a kick only go to Princess Auto or Harbor Freight and buy a battery load tester. They are not overly expensive. Every IronHead owner should have one. Saves those stupid trips out to get it load tested.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Every Ironhead owner with a battery.
mickey t's Avatar
So
Now that you explained it like that I should probably go buy a new battery....I will do the test like you explained though
mickey t's Avatar
I do not I e that after I do a full charge n I wait a couple days I hook up the charger again n it shows low w the red light...then after a bit it'll turn green for the full charge
mickey t's Avatar
Good point
