0 15 min rides
0 new dude
Last Post: a-sad-anorak
0 Need help picking new mufflers
0 48 O2 sensor?
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
0 Help me with the physics of the Bendix float
0 Battery melt down
Last Post: Guidorey
0 removing clear coat on fork lowers
Last Post: LLOYD883
Last Post: sdsbassist
0 2003 1275 BFH 120hp still pings when going full throttle
0 harbor freight lift
Last Post: Kbetts
Last Post: PetesPonies
0 Starting issues (No Spark)
0 73-84 big twin rear wheel
Last Post: einheit 13
0 Howdy ya'll
0 Common ironhead problems
Last Post: clif02
0 back to factory clutch
0 Greetings from Denmark
ken_in_il (60), big andy (56), RogueFTW (54), higdon1200 (49), sastchimo (48), NUcadet12 (42), jswoperator (40)
Old 15th November 2019
stikflote stikflote is online now
Sportster/Buell Model: sportster xlc
Sportster/Buell Model #2: xlh 1200 c
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Triumph Kawasaki
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Default Derby cover
hi lads, can i ask a silly question which side of bike is the Derby Cover ??
don't think there's such a thing on my other bikes,
thanks
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Left. On the primary cover
Old 16th November 2019
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
Look up a picture of a clutch cover on pre-'65 panhead or knucklehead and you will see that the cover resembled a Derby hat. Internet wisdom is that the resemblance started the nickname "Derby cover", which now is synonymous with "clutch cover".
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
harley506d's Avatar
Sportster/Buell Model: 1200c
Derby cover screws are T27 Torx if recall. Golden rule with Torx is to always try the next size up, just in case! The cover O ring can be re-used and you might need a few small blobs of blue Hylomar to help hold it in place in its groove.
Read this before you start.
http://sportsterpedia.com/doku.php/t...vo:priclutch01
mwXL 2006's Avatar
mwXL 2006 mwXL 2006 is offline
Sportster/Buell Model: xl 1200c custom
mwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to behold
try this
https://www.ebay.com/i/283667048417?...SABEgJrAPD_BwE
Xl 1200c custom 2006 carb.
42 CVP pilot 180 main
3 out a/f screw
V&H straightshot slip-ons
K&N Hi-Flow 587 air cleaner
Breather Bolts to air
Love to ride. Stay safe
Milt
http://sportsterpedia.com/doku.php/start Use it great info
https://postimages.org/ for your photos
That Ebay cover shows the classic "Panhead Emergency Brake" damage that happens when you go down into a slide on the primary side! I still have one just like that in the garage from when I did.
