0 winding idle up excessively to start bike.
Last Post: 73HEAD
0 are these siftons
Last Post: mct496
0 Rebuilding and Tuning a S&S GBL carburetor
Last Post: mct496
Last Post: Diogenes415
0 Compensating sprocket.tighten and "pop!"
0 oil dripping fom carb
Last Post: maxedd
0 Primary cover screws... Washers??
Last Post: 72 Ironhead XLH
0 1979 1000xlh front drive (chain) sprocket tourque
0 Screamin Eagle heads
0 New to me timing mark
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Clutch Went Out Of Adjustment - Grenade Plate
0 why you can't be seen
0 What makes a Hugger a Hugger?
0 shifter shaft bent
0 time will tell, but...... (blacked out: fad?)
5 Are you married or single???
Last Post: AlexD
0 1200S Fork Slider Differences 1999 to 2000
Last Post: 84rzv500r
0 Special tools
Last Post: thefrenchowl
0 Dealer says, "Sportsters are just a Phase"
Last Post: handa700
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 Clutch spacing 1979 1000xlh
1911Bronco, Blackbird (84), thai808b (67), Nathan71 (53), lucky-13 (51), Barndog (49), discobanjo (45), albana (43), pat5150 (38)
Old 10th June 2020
Gold Member's Avatar
Sportster/Buell Year: 1972
Default 1972 Build thread please subscribe
Starting my build thread. 1972 with electric start. This is the only pic of it put together since I bought it. Started looking it over and started finding this broken, that missing, that broken, this stripped, C/S bearing blown out, pistons galled, oil lines crossed.
Had the cracked 72 case C/S area welded and machined then decided to go with my E73 instead and had that worked on. Had trans area line lapped to accept 72 trans door. Pics later.
Sorry for the blurry pics. I'll work on that.
Have new bearings for rear wheel and swing arm. Waiting on a new left side locknut.
Working on fitting a repro 72 taillight to a repro 73 fender today. It came with a repro tombstone, broken of course.
Brought home a package of preparation H and a tub of GOJO yesterday. Put it on the kitchen counter. The wife thought they went together and the GOJO was a constipation remedy. Go, Joe!
Stop by my build thread:
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Old 10th June 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Subscribing. Gitter done. Good luck.
Traveled to
Old 10th June 2020
Looks like some solid welding around the C shaft bearing. But because it's machined flat won't the shaft end play shim need to be thicker than the depth of the 1st gear recess it sits in? If not the gear will rub against the case.
Is that groove leading to the bearing for oil? Good idea.
Old 10th June 2020
ferretface's Avatar
ferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant futureferretface has a brilliant future
I think so too. But that is a closed bearing, and unless you have a hole in the bearing shell, the only way for the oil to get to the rollers is through the c/s thrust washers, right end. In another thread, it was recommended to make that clearance less than .010". That doesn't leave much room for Formula Plus to seep through...
Still a good idea. Better than not having it.
Old 10th June 2020
Sportster/Buell Year #2: '03
interesting.for now i'll just comment on the oil slot.the factory used a vertical slot,how would a 45 degreee slot improve on that? gravity being key here.
Old 10th June 2020
Joe_jeep's Avatar
Joe_jeep Joe_jeep is offline
Joe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond reputeJoe_jeep has a reputation beyond repute
i would think preparation h and gojo mixed would burn like hell?
at that point you you are praying for gojo with no pumice!
Old 10th June 2020
I think the fact that it’s longer than the factory slot helps tremendously. I’ve noticed tons of pics of cam cover bushings installed with their slots at angles other than vertical too.
Old 11th June 2020
Parker 1000 Parker 1000 is offline
Sportster/Buell Model: Xlh/Xlch
Sportster/Buell Year: 1976
Parker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to behold
Its not until you get home that you find countless things wrong with it that did not show up on the first inspection. That is true with used cars also!
Old 11th June 2020
Put the tail light on today. Had to dremel a hole for it. Took the better part of 2 days to get it done. Not 16 hours of work, just 2 days.
Made a rubber gasket for tail light.
Put the speedometer on. Spray painted the Pingel rear motor mount so moulding sand won't stick to it. Going to try casting some copies of it in molasses based green sand.
Putting a new rear sprocket on using Big Twin rivets per Dr Dick. Need someone to hold it for me. Had bungs put on new tank for gas gauge.
Heads done. I've had them for a while. New exh. valves, +.002, which my indie said was nothing. Painted black. Brand-clean.
I forgot to mention earlier that I installed grease nipples for the swing arm bearings. The PO had hit the threads taking it off with a punch. That must mean the motor has been out in the past because there's no way to get your fingers in there? So I bought a right side nut to make a thread chaser, then cut the slots in the left side nut because I forgot what the hell I was doing. So I chased the threads and am waiting on a new left side nut. Probably will have to make a homemade spanner for it.
Drilled drainage holes at the bottom of the seat posts tubes and used a shotgun brush to clean out the tubes. I think when I put the springs in they are supposed to be liberally greased like crazy?
Old 11th June 2020
ferretface's Avatar
My '83 case doesn't have any c/s oil slot. Is that something only the early cases have???
