0 71 XLH Value?
Last Post: JimVonBaden
0 The Strociek Project
0 Looking for community help/steering/front end issues
Last Post: tkvalentine
0 Crankcase drain
5 Thunderstorm pistons in xl??
0 sportster revival
Last Post: 73HEAD
0 Trouble removing old license plate
0 Posting Pics
Last Post: BigAl57
7 2001 xlh 1200 off road
Last Post: Warlock
0 Allegheny National Park III
0 Hello From Brighton, England
9 Very long pullback handlebars required
Last Post: Elzer0
0 Japanese Cush Drive!!
0 Canadian Purchases
Last Post: XL Ed
0 best set up for ease of kick starting
Old 2nd April 2021
Sumitagarwal Sumitagarwal is offline
Sportster/Buell Model: N/A
Sportster/Buell Year: N/A
Sumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the roughSumitagarwal is a jewel in the rough
Default Lowbrow Tsunami fender - drill 2-up hole?
Hey folks, I'm in the process of doing a tracker overhaul of my 2003 but I still want to keep it usable as a 2-up for short rides.
I like Lowbrow's Tsunami fender, which is only drilled for a solo seat. It looks like its *probably* long enough to drill the mounting hole for a standard 2-up seat, but does anyone know for sure?
This the fender: https://www.lowbrowcustoms.com/produ...003-sportsters
I'm thinking the Saddlemen Step-Up will complement the overall tracker look.
Old 2nd April 2021
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
this one is on my 1983 XR1000... I can measure for you... I slotted the holes 1.5d to get the final adjustment just right ...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" dunlop trailmax mission 120/90 and 140/80 rear XR1200X perf shocks with 1" lift blocks...
1983 XR-1000S to XR-1000RX Project Build Thread
Old 2nd April 2021
You the man! That would be much appreciated, as I contacted Lowbrow and they weren't that helpful =/
Awesome XR1000 project! I only recently discovered that model, they're such cool obscure bikes
Old 2nd April 2021
Whoa, your thread is also exactly what I was looking for... I've been thinking of putting an USD front-end on my 2003, and the obvious choice would be an XR1200 front-end but I couldn't find info on whether it bolts right up. If I'm reading your thread correct, sounds like it does??
How hard is it to source XR1200 front ends? I also wonder if XL1200CX fronts are interchangeable too.
Old 2nd April 2021
well the 1999S front end was a bolt on to the 1983... and the 2012 was a bolt on to the 1983, not sure about 2003... check sporsterpedia.... I have 2 XL1200X front ends.. Kinda one used and 1 new... the used natural triple tree on the XR with new legs and the used stuff i bought is going on my 99 1200S with a new Black triple tree.. maybe this weekend as its prolly too windy for boating and drinking.. Ill measure for you this weekend but the Magic 8 ball eyeball says yes it will fit...
Old 2nd April 2021
its a bit more than just bolting on though... spring rates, damping rates, and fork length all come into play for what you plan on doing...
Old 2nd April 2021
Never saw Sportsterpedia before, super helpful! And yup, all along the East coast its been very windy lately. Was in Key West a couple weeks ago and couldn't get out on a boat because of that.
Definitely expect to get new springs/etc to suit my bike. And guess I'll need to source the front brakes from the XR1200 too.
Wheel-wise the XR has its own axle size, right? So I'll need either an XR1200 wheel or get a wheel laced up to that hub?
Old 2nd April 2021
wheel choice is a little more challenging... two sizes 3/4" (early) and 1"/25mm (later) using 3/4 wheels on a 25mm axle is not a Bolt on... the 4 piston calipers should bolt right up VROD and others... Im using the XR 1200 front and rear calipers on my 83... the rear was not a bolt on either...
brake rotor spacing is also tricky depending on which wheel you use: narrow mid and wide geometries exist... XR1200 is mid... Brake Rotor overall diameters, hub diameter, thickness all have to be taken into account (2 styles) also there are wide band and narrow band rotors... wide will work with narrow band calipers but narrow band rotors not a good idea with wide band calipers... and be careful using earlier laced spoked wheels as the later 4 piston calipers can interfere with the spokes on ealier wheels... my head hurts now.. more later... if you want to know about using 18 or 19 inch front wheels on the rear..
Old 2nd April 2021
Hah, I appreciate you hurting your head to help me out.
Sounds like basically the best thing is to use XR1200 calipers, rotors, axle, and wheel all from the same or similar year. I noticed this Performance kit here: https://www.shoputahharley.com/produ...nt=33032877316 Are you saying that for mounting to my frame it'll simply use any XR1200 triple?
I plan on leaving my rear brakes and setup as-is but maybe having Cognito build a 19" wheel on an Excel rim and my original OEM hub.
Old 2nd April 2021
I bought exactly that kit for my XR1000 after sniping parts on fleabay to mock everything up... now the mockup parts that are perfectly functional are headed for my 1999 XL1200S... YMMV
