0 Need some info for my small stroker build
Last Post: RKN
0 Parts manuals?
0 Coulda' - Shoulda' - Woulda' - Solenoid/Bendix?
0 What is this shifter?
Last Post: 73HEAD
0 Greetings from NorCal/Nevada
Last Post: Jhbox13
0 Calling ALL Sportster Baggers...Post your pics and what you did to your Sportster!
Last Post: JimVonBaden
0 WTB right front foot rest mount/brake pivot
Last Post: RandallM
0 Pegs vs floorboards
0 Traffic Stop
Last Post: amyst
0 Can't install kickstand spring
0 2022 Sportsters
Last Post: ZCarFan
0 extortion
0 Video - STOP Saying Harley's NEED Backpressure! It's a MYTH!
0 A Reliable Engine
0 Speedometer
3 Rear galiper bracket spec.
Last Post: 84rzv500r
jurneyman (80), AdO650 (66), xlsport (64), darth (61), mcsmokinp (57), stalkie (57), unleashed66 (56), 66xlch (56), lownslow (50), hrg (48), Ironduke (46)
Old 31st July 2021
rocketnorton's Avatar
rocketnorton rocketnorton is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: homebilt fxr
Other Motorcycle Year: 80+
rocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud ofrocketnorton has much to be proud of
Default drum f wheel/bearing ?
70 xlch
right side bearing just drops in
sloppy enough ya can see & feel it movin in hole
prolly couple thou
any thoughts/ideas?
concerned bearing movin around in there will just wear the hole more
tia
pete
Old 31st July 2021
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: FXR
Sportster/Buell Year #2: '89
Other Motorcycle Model: R50/5
Other Motorcycle Year: '73
Fivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond reputeFivecats has a reputation beyond repute
Get some shim stock. Cut to a size that will allow you to press the bearing in with reasonable pressure.
If its not that loose use a punch and dimple the surface {raising it} enough to fit the bearing, with reasonable installation pressure.
Old 31st July 2021
one idea i had, too, was shimmin it
some cheapo feeler gauges might be in order
thx
Old 1st August 2021
Gold Member's Avatar
Sportster/Buell Year: 1972
There's an industrial supply hardware store near me that has that hobby display of metal sheets K&S I think it is.
Dimpling the inside of the drum is commonly done too.
Look into Loctite 680. It is a gap filling liquid/glue stuff that is specifically for this kind of application. I used it on my loose-ish neck cups. I haven't ridden it yet but the specs for Loctite 680 looks like it will work fine. Thousands of pounds of compressive strength. It has a long working time. You could put the bearing in, install the whole shebang back in the fork, and it will set up properly aligned.
Stop by my build thread:
[url]http://xlforum.net/forums/showthread.php?t=2076933[/url]
Four wheels move the body. Two wheels move the soul. Three wheels move the bowels.
Old 1st August 2021
ill look at that stuff
thx
Old 3rd August 2021
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
Another thing to check is if the bearing bore in the drum is round or egg-shaped, or if it's a larger diameter at the outside than at the deepest point. If it's wallowed out, you might need to consider boring and sleeving it.
When you hear hoof beats, think horses-- not zebras.
Old 5th August 2021
havent got to measuring it yet
hopin that is not the case tho
Old 6th August 2021
I'll keep my fingers crossed too.
If it is, now's the time to correct it. Locktite is a good fix but often temporary.
If there's any movement, it's not gonna heal itself.
Old 6th August 2021
yep
have 2 others, so havent been on it since posting
waitin fer cool day to looksee
dont wanna f up a hard to find part
Old 7th August 2021
Smart. I've got Sportster drums front and rear on mine and ended up going out of town for the last of what I needed.
