0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: 84rzv500r
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
Old 5th August 2021
Mr.Rowdy's Avatar
Mr.Rowdy Mr.Rowdy is offline
Mr.Rowdy is an unknown quantity at this point
Default Hammer 1275 UPDATE...
Okay folks. Sent my cylinders and pistons to Hammer. According to Dwayne they were a bit out of spec as far as piston to cylinder wall clearance. He did not give me specs. They sent me another set of jugs fitted to my pistons, new rings already gapped and all installed in the jugs. I didn't really get into the blame game with them, they sold the cylinders to me at a very discounted price. Fair is fair.
I got the stuff around 1pm and had the bike running by 5pm. At this point it has fresh (again) cylinders, new lifters, valve springs, the Dyna ignition and wires, new plugs, freshly built CV, the Reaper cams, new bronze oil pump drive gear, new oil sending unit, conventional 20w50 oil, a fresh tank of 91 octane.
It fired immediately, new lifters tapped. Following the heat cycle procedure the lifters made noise until the fourth heat cycle. After that nice and quiet. Went for it's first spin and all was good. Let it cool, then went for about a 4 mile spin and all is well. Kept it under 3k with some 1/2 throttle bumps and engine braking in decel. Feels fine right now. I'll take it easier this go and see how things develop.
So that's where it's at.
Old 5th August 2021
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: 1968 XLCH
Other Motorcycle Model: '89 FXRS, '73 R50/5
Other Motorcycle Year: '89
Fivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant future
Far out... when it works it works.
Old 5th August 2021
Mr.Rowdy's Avatar
I'm still curious because it seemed to run fine before too, until I broke rules and ran it hard. I'm still not sure if it is gonna have the same top end rpm issue. Guess I will have to wait 495 miles to find out. That's gonna be hard.
Old 5th August 2021
rejeanprimeau's Avatar
5w20 oil is pretty thin for those engine ???
Old 5th August 2021
XL Ed's Avatar
XL Ed XL Ed is offline
XL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond repute
What he said...
Old 5th August 2021
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Good to hear you're getting things resolved. Take it easy, and good luck!!!
John
Old 5th August 2021
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
20w50
Old 5th August 2021
http://hammerperf.com/ttinstallkit.shtml
OIL: For break-in purposes, any low cost grade of 20W-50 oil will be fine. We actually use the Wal-Mart branded stuff that comes in gallon containers. After break-in (see below), change your oil and use your favorite brand of high quality 20W-50 motor oil, preferably something formulated for air-cooled V-Twins.
Old 5th August 2021
Mazdog355's Avatar
Mazdog355 Mazdog355 is offline
Sportster/Buell Model: XL883C
Mazdog355 is an unknown quantity at this point
Yup, I used the Walmart super tech 15w40 to break in my 1275 kit and followed the break in process pretty closely (it was hard…).
Switched to Amsoil 20w50 and now have almost 2000 miles and no problems, no oil burning and the oil stays golden brown.
2004 XL883C ---> 1275cc Hammer
Old 5th August 2021
Mr.Rowdy's Avatar
Sorry, it's 20w50. I took it for another spin today. Seems like the 45 pilot is a bit rich, doesn't like any choke at all but it's been pretty warm here. I'm gonna leave shit alone. It's running smooth and feels a tad rich but I'll give it time.
