0 1967 XLCH stroker project
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 31st January 2006
Lone Wolf in Canada's Avatar
Lone Wolf in Canada Lone Wolf in Canada is offline
Sportster/Buell Model: XLC Custom 1200
Lone Wolf in Canada is on a distinguished roadLone Wolf in Canada is on a distinguished roadLone Wolf in Canada is on a distinguished road
Thanx, Rensselaer, I believe you are correct. And ed in az for the web page,
I read a book that told me they move together, I just couldn't believe it. Thought there would be more vibration as one post here said. But then, a single cylinder moves up and down solo and it feels smooth.
Hope this question informed others also.
Old 3rd February 2006
Turbota's Avatar
Turbota Turbota is offline
Since this thread is something titled "Potato Potato" .... I can tell you one thing. If you use a 2-1 pipe on your Harley. you can pretty much forget about the "Potato" sound.
In fact, my bike with an RB Racing pipe don't even sound like a Harley anymore ... What does it sound like? ... I have no idea.
04 XL 1222R
Old 13th February 2006
ctilson ctilson is offline
ctilson has disabled reputation
Here is a page on Harley sound from a how H-Ds work article.
http://science.howstuffworks.com/harley3.htm
dmraco's Avatar
dmraco dmraco is offline
Sportster/Buell Model: Sportster Forty Eight
Sportster/Buell Year: 2012
dmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of light
Originally Posted by xl1200r
Techi person, here I go...
The pistons move sort of together, they are actually 45* apart on a common crank pin. What was said is true, they alternate which piston is firing. So while on piston fires and forces both down, the other has the intake valve open and is drawing in fuel (4 strokes...Down(intake), up(compression), down(ignition), up(exhaust).
What makes the "patato patato" sound is that the engine is "odd-fire", in that the spacing between the firing is not equal. You get cylinder 1 to fire, the crank turns 315*, then cylinder 2 fires, but the crank has to turn another 405* for cylinder 1 to fire again. This is due to the 45* piston angle and the common crank pin. This means that there's almost a 30% difference in the amount of time it take for each cylinder to fire from the other cylinder firing.
I wish I could find this animation of the whole thing happening - it's be much easier to understand when you see it.
Try this:
Hope that helps.
That is extremely helpful!!! Learn something everyday!
2012 Sportster Forty Eight
kiwinz kiwinz is offline
kiwinz has disabled reputation
Garden Diagnostics :
Tomato Tomato /poss exhaust leak or tappet
Zuchini Zuchini /poss intake leak or clogged exhaust
Carrot Carrot /small end clearance excessive
Jimbo999's Avatar
Jimbo999 Jimbo999 is offline
Riding with Angels
Sportster/Buell Model: Sportster XLH 883
Sportster/Buell Year: 1988
Jimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the roughJimbo999 is a jewel in the rough
My old AJS twin would hop on idle due to both pistons moving up and down
together. Smoothed right out on acceleration. It was kind'a cool in a way.
Sitting at a stoplight the forks would slide about 1".
Try n' catch the wind
Stage 1
Taxes Paid
Blue Loctite is your Friend
Old 27th September 2007
juddster juddster is offline
juddster is an unknown quantity at this point
I heard the the reason why the pistons rotate so close together is because the engine is based loosely on an old 10 cylinder bi-plane engine; the engine is 2/10ths.
sprtrjl sprtrjl is offline
Other Motorcycle Model: Heritage Softail Classic
sprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nicesprtrjl is just really nice
I like this explanation:
a Harley engine does this:
a piston fires
the next piston fires at 315 degrees
there is a 405 degree gap
a piston fires
and so on... So at idle you can hear the pop-pop sound followed by a pause.
Old 28th September 2007
MadMax25's Avatar
MadMax25 MadMax25 is offline
MadMax25 has disabled reputation
XL1200R wrote: 'The sentence in the link is worded poorly, but what it's getting at is that a 45* V-twin that makes 70hp has more "actual" power than a 360* parrallel twin making the same 70hp.'
Not wanting to start a torque vs hp debate, I present the following...
OK... notwithstanding crank HP vs rear wheel Hp
actual HP... real HP... bunch of crap...
70 hp is 70 hp... you can quote me on that...BUT
What does the hp curve look like going up through the RPM band?
Where does the torque peak?
With HD, the torque tends to peak early in the RPM band.
There is a sensation of power in that early peaking torque.
Torque = force times distance.
Force is the power of the explosion above the piston pushing it down.
Distance is the amount of offset the crank pin has from the center
of rotation of the crankshaft.
That's it... that's all... no magic involved.
Any ride is a good ride, when you and the scoot
make it back to the garage, in mostly large pieces.
MadMax25
Old 24th November 2007
dave76's Avatar
dave76 dave76 is offline
Senior Master Bike Builder
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
Also remember Harleys engine is basically an airplane Radial engine with just two cylinders. Just check out some old photos of WW2 B17s and the Navys Hellcats. Thay were all radial engines, with cylinders spacing 45° appart.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
