0 TC88A maps for 1250 Sporty
Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Old 28th January 2005
Blaster1200 Blaster1200 is offline
Blaster1200 has disabled reputation
Default Rear belt pulley question?
Hi all!!!
Just making sure I have this right?
Adding a smaller rear pulley will lower your rpm's at higher speeds? In other words, at say 65mph you'll turn LESS RPM's with a 61 tooth rear pulley than you would with a 65 tooth pulley?
Alasportster's Avatar
Alasportster Alasportster is offline
Location: Athens, Alabama, 12 miles s of the Al-Tn line
Alasportster is on a distinguished roadAlasportster is on a distinguished road
That's it, smaller in the rear reduces RPM at a given speed.
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
and even less with a 58 or the European 55. You have a 63? I thought stock was 61.
What anyone else thinks of me is none of my business.
Actually I have a 68 tooth rear pulley (2004 1200 custom). I was thinking of going to a 61.
rottenralph's Avatar
Correct me if I am wrong but you will probably need a newer belt. I have Euro gearing on my 93 and my sweet sport on the highway is 80 so be careful because these bikes vibrate more at certain rpm ranges and you don't want the highest amt. of vibration to be at the speed you normally drive.
Old 29th January 2005
Stephen Hawk Stephen Hawk is offline
Stephen Hawk has disabled reputation
I thought the 04 had a 29/62? I switched to a 28/62. There is a bit of vibration between 3,000 and roughly 3,150 however, I generally ride at 3,200-3,300 on the road, which is rougly 72-75 mph. At that rpm the vibration is gone.
Hawk
Yes I will need a different belt. I pretty sure a belt from a '03 will work, being that the '03 has a stock 61 tooth rear pulley.
Mechano's Avatar
Mechano Mechano is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: Suzuki Bandit 1250N
Other Motorcycle Year: 2008
Mechano is an unknown quantity at this point
Hawk
From manual:
883 (all models for any market)
28 front 68 back.
1200 (USA models)
29 front 68 back
1200 (intl models)
30 front 68 back
Considering that 1 front sprket/pulley is equivalent to near 3 back pulley, I'll prefer to don't go with more than 1 tooth plus or less on front pulley (that is less expensive too) or if it's available at reasonable price it's preferable with a 2 teeth plus or less on rear pulley.
For international 1200 that will want to obtain better acceleration to compensate exhaust, ac, cam mods that will let them loose in low-end torque there's the cheap way to find from US the front 29 USA 1200 models.
For USA guys who want to do the same, there's the option of the 883's 28 front sproket.
For better mileage and lower revs at highway speed the USA models can mount the intl 30 sprocket.
I think there's still no way for intl models to have longer gears.
Similar Threads
Just finished upgrading my run-turn-stop rear lighting system mikeabe Sportster Motorcycle Motor - Top End 22 10th March 2014 01:16
Pulley Question Shamdog Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 23 15th May 2005 22:13
Dyna/Softail pulley on XL? Mechano Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 2 23rd February 2005 20:14
Broken Belt kjbsporty Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 4 20th February 2005 15:03
Bigger rear pulley Mechano Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 9 28th January 2005 12:29
