Last Post: Hank21113
0 too bad
0 Head gaskets.
0 Dynamic timing the 2000i?
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 blonde, brunette, red?
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
0 Nighster seat on Iron
Last Post: ed_in_az
Last Post: lo-rider
Old 29th January 2005
XLFREAK XLFREAK is offline
Default Fork Screws
Hello, I am going to relocate my front signals to the forks. Question is, the relocation kit calls for taking the lower fork pinch screws out, will the forks move if I only do one side(screw) at a time? And when I put the screws back in how tight do they need to be? Any help is very much appreciated.
Also, I don't have a lift, can I do this with the front wheel on the ground?
Thanks.
scooter's Avatar
scooter scooter is offline
scooter has disabled reputation
I did that to my turn signals. Do one side at a time. The tubes will not slide if you only loosen the bottom one side at a time. The pinch screws should be torqued at 30-35 ft lbs according to the manual. It's a fairly easy job.
Thanks a lot.
Similar Threads
Progressive Fork Spring Installation DaleG Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 17 20th May 2016 00:33
progressive part # ? Nightrider Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 7 8th April 2010 01:27
Fork tube nut!! Nightrider Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 18 4th May 2005 20:01
Fork Travel 04 1200R Mr Davo Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 3 30th January 2005 19:33
changing fork oil engine Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 20 26th November 2004 20:33
