Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 16th May 2008
rotten01's Avatar
rotten01 rotten01 is offline
Sportster/Buell Model: 883 convert to 1200
rotten01 is an unknown quantity at this point
Default 1996 Sportster wiring questions!
Hello & thanks for the help with this project. This my first build/rebuild. I am chopping my 96 that was originally an 883 & now has the 1200 kit on & proved. I am bobbing & chopping the bike & want to eliminate the speedo & all turn signals. What needs to be done with the wire ends that were connected to these components? Can they just be terminated & isolated or do they need a special connection to complete any circuits? I will be posting before, during & after pics when & get them assembled. Almost all the parts needed are in the garage & disasembly & rebuilding has started...Thanks again, Rotten
Old 16th May 2008
rotten01's Avatar
Default Quick shot
This is me on the 96 Sporty as it was for many years. "The before pic". I will post as I go along with the project. It will be a very different look to a great ride. Thanks for your support...Ride safe, Rotten
Old 16th May 2008
toddjsn's Avatar
toddjsn toddjsn is offline
Sportster/Buell Year: 1989
toddjsn is on a distinguished roadtoddjsn is on a distinguished roadtoddjsn is on a distinguished road
I'm not a expert or anything but if it was me I would just cut the wires. maybe put some tape or shrink wrap round the ends.
Old 17th May 2008
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Yes, you can just cut them and make sure they don't short to
anything else.
dec
Old 17th May 2008
JonnyRtn's Avatar
JonnyRtn JonnyRtn is offline
Sportster/Buell Model: 1200 conversion
Sportster/Buell Model #2: FLH
Sportster/Buell Year #2: 1971
Other Motorcycle Model: FLHTC
JonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura about
If you get a factory manual you can Isolate and remove all the unnecesary wiring... but if you follow this diagram all you need to do is buy an ignition set up... built this harness in about 2 hours with a NAPA automotive style switch..
Bolting foo foo on... is not building.... The dealer is not your friend, he is like the IRS, just wants your money.... Chopping up perfectly good motorcycles is fun, try it, you might like it...
Old 17th May 2008
rotten01's Avatar
Thanks, I am using the existing harness. Your info helps.
Old 17th May 2008
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
if you end up snipping off the amp multi pin connector for the speedo and trouble lights I could use it.....
2002 157 hp sportster nearly in the nines...
1995 Blacked out Cafe style 1200 with xb conversion.
The cannons don't thunder ,there is nothing to plunder.
My Caribbean yearnings 200 years late. I am a forty year old victim of fate. Arriving on the scene 2 centuries late. Alas I am glad still, for having found me best mate. With the wind in my sails...n the rubber side down, I cruise dangerous land ,they all know me in town. No parrot, no sword..with regular life I be bored. So I does what I can, We don't set ships a sail,we aint walked no planks, but we live best we can and for that we give thanks.
Old 18th May 2008
rotten01's Avatar
hey Narley, I will let you know!
Old 19th May 2008
SpringerSam's Avatar
SpringerSam SpringerSam is offline
Sportster/Buell Year: 70
Sportster/Buell Model #2: Softail Springer
SpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished road
Caution...if there is more than 1 wire on a terminal, they must be connected together then tape or heat shrink the connection.
Old 19th May 2008
ReddTigger's Avatar
if you have the headlight bucket (eyebrow mount) There are connectors for that stuff. You can just unclip them in the bucket.
or you can follow the leads back to the originating spot on the harness, clip the wire and use some liquid electrical tape or plastic dip on the end.
States I've Ridden in
71.3 hp 70.8 tq
