0 WTF Happened
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
0 Cylinder Piston kits
Last Post: jordan1200
0 05 and 73
0 What is this?? 07 efi 1200 weird box
Last Post: Hank21113
0 Brake light stays on
Last Post: jammantoo
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
0 Tool Roll Help
Last Post: ReddTigger
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
0 Back in Sporty Land
Last Post: skien
Last Post: The Crusher
Old 30th January 2005
Pay Toilet Pay Toilet is offline
Pay Toilet has disabled reputation
Default New top end going on my 79 Ironhead...
well....after doing a leakdown check on my motor, it became painfully apparent that despite all my efforts to address the oil burning rear cylinder, something had taken big shit....
This is an original two owner 79 Sporty with just 8k on the clock...I think the last owner truly F'd this bike up trying to get an ancient Lectron carb to work on it. So anyway, I went to the liqour store to get started on the rebuild...
Heres a few quick pics of the tear-down....
here is a pick of the suspect piston....looks like a limp dick....the rings looked almost "polished"...they were pretty worn...and the piston had a little more than the usual scuffing...time to start a new life as an ashtray....
heres the rear jug....stock bore..not bad shape, but has a decent taper to it....it will get a visit from mister boring bar....
heres a shot of the rear head...not bad, but its hard to tell by the pic, but there is a ton of carbon on there....musthave been glowing quite niceley when hot....a valvejob and new springs will give it a fresh start in life...
I think at sometime, all sportys top end's get to hangout on a workbench and watch us run around trying to find shit we lost or misplaced!
we will be getting the cylinders cleaned and maybe powdercoated black and get the rocker boxes redone and polished...should be a nice top end when its done..i'll keep a few pics going as I progress....Cheers
Old 31st January 2005
Compare with the pics in message #8 of "First Time Cylinders Out" in this IronHead section.
Similar Threads
1973 Ironhead Sportster runnin' early mag? t-bonewilliams Sportster Motorcycle General Discussion and Problems 12 20th February 2011 01:17
I just bought an Ironhead Ron Richtofen Ironhead Sportster Motorcycle Talk (1957-1985) 4 4th April 2005 13:07
oil filter install on ironhead bamf_shadow Sportster Motorcycle Motor - Top End 4 14th March 2005 00:32
ironhead benny04hd Sportster Motorcycle Motor - Top End 1 12th February 2005 13:52
