0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 20th May 2008
mvhgraphics's Avatar
mvhgraphics mvhgraphics is offline
Sportster/Buell Model: 1200N
mvhgraphics is an unknown quantity at this point
Default Running Lean/Pipes blueing
I've just picked up a 07 Nightster with 800 miles on her. and I've noticed the exhaust header is blueing under the heat shields (not bad but around the cylinder heads)
1. Will i be doing any damage to engine till I make my first service?
2. Is this because the previous owner had Screaming Eagle slip-ons installed?
3. Will this be adjusted and corrected when I take her in for Service?
All help and Info appreciated.
MVH
Old 20th May 2008
blakjak's Avatar
blakjak blakjak is offline
Sportster/Buell Model: Honda CBR 929RR
blakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura about
They'll adjust it if it needs it but some blue on the pipes around the exhaust port is normal. It's just because it gets so hot and the factory sets them lean to begin with. I wouldn't worry about it.
Old 20th May 2008
shotgun46's Avatar
Agreed ! Its about how it runs and did you check your plugs !
Sportsters Rule ! :banana
Old 20th May 2008
jrossty's Avatar
jrossty jrossty is offline
jrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nicejrossty is just really nice
Most all pipes are going to blue with some mileage... especially if the bikes a bit on the lean order... My old drags were somewhat blue & its ran great since I got it.
James
aka "Chief James" of the Heavy Horses MC
"Whatever doesn't kill you, makes you stronger"
Old 20th May 2008
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
All chrome pipes will blue or golden. Nothing to worry about based solely on the pipes. You can do slipons on the EFI bikes without changing the EFI provided you leave the A/C enclosed. If you do open the A/C then chances are good you will need to get the EFI reprogrammed or buy an aftermarket fuel program.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 20th May 2008
Thanks!
This is my first Harley, I had an 86 Virago 1100 and had to have the nightster as soon as I saw one. The ride and power is a totally different experience here and I love it. I love the the sound and feeling of those 1200cc's rumbling.
I'm hoping the SE slip-ons won't effect my warranty, being that I'm bringing in a pre-owned HD for first service.
Any thoughts?
MVH
Old 20th May 2008
BINGO that's one of the reasons those CHROMED heat shields are there in the first place.
here's the first day I rode my new Breva, maybe there were 100 or 200 miles on by the time I took this pic - if you look closely you can already see the pipe turning colors just in front of the cylinder head.
Any thoughts?
Not in the slightest
1. Google "Magnusun-Moss Warranty Act"
and
2. Harley sells the SE slip-ons for these models and SAYS they don't require any recalibration of the ECM when used alone (i.e. without a low restriction air cleaner).
Old 20th May 2008
blakjak's Avatar
OMG - Kev, get that hideous thing outta here!!!
Old 20th May 2008
Why do they tune them lean? That means it's running hot right? and the bike is air cooled... This doesn't make sense to me. I had these issues with my Virago, I didn't expect to have this issue with EFI. I just don't want to do any damage.
Thanks!
MVH
Old 20th May 2008
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Thanks!
MVH
I think it's probably to help them meet EPA Emission standards.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
