Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 20th May 2008
CHOPPERSANDFORDS CHOPPERSANDFORDS is offline
CHOPPERSANDFORDS is an unknown quantity at this point
Default 77 motor in 71 frame and another question
i have a 71 that the generator locked up and busted my case well i showed a pic of it and its not worth getting fixed i just got a 77 1000cc engine and bolted it in now i need to know if the primary from the 71 will work on the 77 not the cover the internal parts the chain atc please let me know thanks
Old 20th May 2008
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 2008
Other Motorcycle Model: XLRTT
I've checked the parts books,
Everything internal is the same, except obviously shift lever, its shaft and the chain tensionner assembly.
Patrick
Flat Head Forever
Old 21st May 2008
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
77 has no spring-loaded compensating sprocket on the engine mainshaft. You would have to check if the 71 sprocket fits and lines up with the clutch ok if it has the earlier type compensating spring set up.
Still, sounds mucho easier than welding the generator drive housing back on.
Old 21st May 2008
Ivan RoachCoach's Avatar
Banned
Default What are you going to do about the VIN?
Your existing title, and in turn, your registration, will no longer be valid since it doesn't match the numbers on your motor.
