0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Old 26th May 2008
1200 sporty's Avatar
1200 sporty 1200 sporty is offline
Sportster/Buell Model: 1200 sportster
1200 sporty is an unknown quantity at this point
Default Need Help With Carb. Problems Please!!!!!!
So today was a nice day and I actually had some free time so I got the bike out of the garage and charged the battery and jumped on to go for a ride and no go. The bike was very hard to get started and once it did start it only runs for about 60-90 seconds and then shuts off, it will immediately restart and do the same thing again. So I thought that maybe it just needed cleaned out so I headed down the street and before I even clicked out of first gear the bike shut off, again it immediately restarted but the problem persists and I am at my wits end. If there is anyone out there that has any ideas they would be greatly appreciated. So for the long post just wanted to get all of the info. out there. Thanks in advance.
Shawn
Old 26th May 2008
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Bad gas, clogged petcock filter, clogged in-line filter. Check battery cables. If their somewhat loose this can happen. Most carb problems aren't carb problems.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 26th May 2008
cpmike's Avatar
cpmike cpmike is offline
Other Motorcycle Model: FXR Low Rider
Other Motorcycle Year: 1993
cpmike is on a distinguished roadcpmike is on a distinguished roadcpmike is on a distinguished road
How long has the bike been sitting? Could be water in your float bowl. Take the bowl off and drain it. Make sure your float moves up/down. How old is your fuel?
Old 26th May 2008
thank you for the quick responses i am going to the garage to try these fixes right now.
shawn
Old 26th May 2008
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
I would take the carb off and clean it try soaking it in Berrymans B-12 or gunk carb cleaner. It will be necessary to completly disassemble it and remove all rubber and plastic parts before soaking it. Then blow it out with compressed air real good that will take care of the carb. Then check the other things mentioned here an old trick to see if it is a fuel problem is to squirt gas into the carb throat when it starts to die. BE CAREFUL here that you don't get burned if it farts while you are doing this.
Old 27th May 2008
XLXR's Avatar
XLXR XLXR is offline
Is there a drain bolt under the carb bowl? If there is, next time it stops, turn off the gas valve immediately, and see if you can drain any gas out of the float bowl. If the bowl is empty, the floats are probaly sticking or the filter is clogged. It is possible the main jet or emulsion tube is clogged. It could be water in the gas.
Old 27th May 2008
jharback's Avatar
Remember, always try that which is easiest first.
Old 27th May 2008
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
Check for a cracked or split vacuum line from the carb to the fuel petcock.
[SIGPIC][/SIGPIC] AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
