Last Post: joes95bobber
0 Crank position sensor problems ??
Last Post: bobberman66
0 V.o.e.s
0 Windage Tray
Last Post: Blacky
0 Happy Birthday Folkie!!!
0 Starter Worked, Then It Didn't
Last Post: flthd31
3 Ironhead Pictures Thread
Last Post: Scar55
0 Rear Shock length '81
Last Post: Scar55
0 Home Brewing
Last Post: gravydog
0 This place still sucks!!!
0 Coil suggestions please!!!
0 My '05 1200C (insert clever title here)
Last Post: Ranchero50
0 05 sportster custom and bassani road rage
0 2009 Iron 883 Wont Start!
0 Rear sprockets
Last Post: 85IRONDIRT
0 07 883 Low .... lifting
0 Pictures of Evos that look Like Ironheads
Last Post: hotrodbiker
0 Rear shocks ?
Last Post: wachuko
Last Post: WKNDZ
Last Post: SLW210
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
Old 31st May 2008
ridefree1 ridefree1 is offline
Sportster/Buell Model: 1975 xlh 1000 ironhead
Sportster/Buell Year: 75
ridefree1 is an unknown quantity at this point
Default starter problems
hey all, i am having a problem with my solenoid and starter relay. i had to rewire the bike due to shoddy work by someone else. wen i pus te starter button, it burns te wire from te olenoiid to te relay, im tinking i ave tem backwards, tried a few different ways, still burning, melting the wires, anyone ave a good pic to show how it goes, tis is a 75 ironead, tanks
Old 31st May 2008
Jtrapass's Avatar
Jtrapass Jtrapass is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda VTX 1800 Retro
Other Motorcycle Year: 2002
Jtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished road
haynes and clymer both have great pics and diagrams
you should have a beefy hot wire from the battery to one of the large nuts on the solenoid, then a beefy wire from the other large nut to the starter. You should have two smaller wires, a red from the same nut the battery's line is connected to and a black or some other color from the little brass stud on the solenoid running to the two larger connections on the relay. (the ordering doesn't matter here because it's just a switch). Then there's a smaller stud, probably brass as well, offset on the relay, run this to your starter button. Both of these get ground through the bolts that connect them to the battery box or chassis, so make sure they are firmly bolted down before attempting to use. If in doubt, add an alligator clip.
- Joe
wrenching in my garage with a big stupid grin on my face.
Old 31st May 2008
Default thanks
alright im gonna go look at it again, i do notice that im missing the one wire on the lil' wire for the starter button, maybe i have them backwards, when i first hooked it up, i touched the ground to the battery, and it turned over without the key in, also melted the wires
Old 31st May 2008
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
Here is a generic wiring diagram that shows the basic layout. It may vary a little from your 1975 but the important part from the Battery through to the starter is the same.
The thickness of the red schematic lines is an indication of the size the wire should be.
The optimum for the battery's heavy leads is AWG #2 multiple braided automotive grade cables. These cables should be located in three places Battery +ve Battery -ve and Solenoid to Starter all with well crimped connectors that are best if soldered as well. Then the connection points need to be clean and shiny when clamped down. If you have some dielectric grease to smear over these terminals, nuts and/or bolts the corrosion will be greatly reduced.
Make sure the starter relay is well grounded and the leads comming to and leaving it are 16 Guage braided automotive wires as well.
Hope this gives you an idea and some clarity when checking out your situation.
Cheers;
Old 31st May 2008
hey man thanks, im about done !!!!ing with it for a few hours, gotta cool my jets, the pic is perfect, gives me a good idea now. thanks bro
Old 31st May 2008
SpringerSam's Avatar
SpringerSam SpringerSam is offline
Sportster/Buell Year: 70
Sportster/Buell Model #2: Softail Springer
SpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished road
ridefree1...
Another wiring diagram...
http://www.smokeriders.com/diagrams/...ater%20XLH.gif
Sam
Old 1st June 2008
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura aboutShadowdog500 has a spectacular aura about
I know this is crude, but I just made it because i know this is the type of thing I would need, and your bike is the same year as mine.
The positive battery cable goes to the top lug of the starter solenoid by the starter. Another wire goes from there to one of the main lugs on the starter relay (under battery) A wire then goes from there to the ignition, Then from there to the starter button. Then a wire goes from the starter button to one of the small leads on the starter relay (mine goes to the front but check because the other is shorted to ground internally) Then a wire goes from the other main lug on the relay to the small lug on the solenoid. Then a heavy cable goes form the other main lug on the solenoid to the starter. (clear as mud) I wonder if you are hooking the hot wire to the grounded lug on the relay? That would case it to burn up rather quickly.
Here is a crude picture that I made up from a couple photos of my bike.
Hope this helps,
Chris
Old 3rd June 2008
jagdprcp's Avatar
jagdprcp jagdprcp is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1979
jagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enough
If you are melting wires like that then you have some kind of short. Either the relay is shorted or the wiring is shorted to ground somewhere.
Skeeeter
'76 XLH - 4 5/8" Stroker, Andrews V-9 cams, S&S Super 'E' and Barnett Billet Scorpion Clutch plus some cosmetic stuff
'79 XLH - Mostly stock except for cosmetics (for now!)
