0 Salutations y'all
0 New member in MD
0 Primary Oil INSANITY!
0 Decman's Birtday
Last Post: Outtakes
0 Oil??
0 Ei
Last Post: trappnman
0 What's your helmet?
Last Post: goblin_dust
Last Post: spacecoast
0 Rear tire
0 Show your tank decals
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: Heff
Old 2nd March 2006
73chopxlch's Avatar
73chopxlch 73chopxlch is offline
Sportster/Buell Model: 1000 XLCH
Sportster/Buell Year: 1973
73chopxlch is an unknown quantity at this point
Default Puking oil
Can anyone tell me why? If I don't start her for a month she will puke out about 1/4 cup of oil out of the breather tube. Could I be over filling her, she doesn't have a dip stick or is she just suffering a little spring fever?
Old 3rd March 2006
Y2K's Avatar
Y2K Y2K is offline
Other Motorcycle Model: Electraglide classic
Other Motorcycle Year: 2000
Y2K has disabled reputation
That's normal,they tend to sump oil from the tank to the engine over time and it settles in the crankcase.
As soon as you crank it over it's picked up and spit out the breather on the older ironheads.
Electraglide Roadtripper
Old 4th March 2006
73chopxlch's Avatar
Thanks Y2K. I kinda figured. Guess I have to fire it up at least once a week
Old 4th March 2006
Y2K's Avatar
Y2K Y2K is offline
That's exactly what I used to do.
Be sure and let it run for a while and get good and warmed up before you shut her down.
Give her a few blips on the throttle to clear it up,shut off the gas and run the carb dry till she stops
Shut off still cold or luke warm will cause condesation and acids from not fully burned mixture and not enough heat to expell any existing stuff in the engine.
This will cuase corrosion in your engine.....bad ok
Old 5th March 2006
73chopxlch's Avatar
OK, thanks man!
