0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Drive Chain Adjustment
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 1968 XLCH Oil Leak
Last Post: ktskaggs1
Last Post: tvon
Old 5th March 2006
72nova72 72nova72 is offline
72nova72 has disabled reputation
Default Is this a clutch or an adjustment problem?
Hey everyone. I hope someone can help me out.
I have a 1979 sporster xl. I'm having a very hard time squeezing the clutch lever in to disengage the clutch. Even with the lever pulled all the way in. The clutch is pulling. Meaning I have to hold the brake in first gear at a light or the bike will keep going. I bought a new clutch cable but that didn't fix it. Any suggestions? I was thinking the clutch might be worn out. If so, Does any know how to make a home-made clutch removal tool and clutch basket holder tool. Thanks
Old 5th March 2006
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
I have 72 XLCH and the clutch rod adjustment under the left side cover should be checked. I would also check the primary fluid. Hopefully, you are running sport trans or some other compatable fluid. A bad clutch plates usually calsue slipping not drag.
SEMJPM
Old 5th March 2006
XLFREAK XLFREAK is offline
i this were a car ide say pressure plate spring broke off and jammed under diaphragm or clutch fork is bent.
for whatever reason your clutch is not fully disengaging
Old 5th March 2006
a45junkie's Avatar
a45junkie a45junkie is offline
Master Bike Builder
Sportster/Buell Model: XLH883/1200
Sportster/Buell Year: 96
Other Motorcycle Model: CX500
Other Motorcycle Year: 84
a45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nice
if the adjusting procedures check out i would have to say probably a warped disk
96 XLH883/1200
BUB Reinhart 2-1 exaust fitted with supertrapp muffler 24 disks
big sucker stage one
progressive suspension
Old 5th March 2006
i would agree with warped disc dragging except that he says squeezing clutch is difficult.
Old 5th March 2006
BobbyB BobbyB is offline
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 2004
Other Motorcycle Model: FLHRCI
BobbyB has disabled reputation
Is the lever pull harder than it was before or are you new to ironheads. If you're used to metric bikes then the pull may be ok. When installing the new cable, slack the cable first. Then set clutch adjustment, then set cable adjustment.
Bobby
Old 5th March 2006
MOREHP's Avatar
MOREHP MOREHP is offline
Sportster/Buell Model: 86 883/1250
MOREHP will become famous soon enoughMOREHP will become famous soon enoughMOREHP will become famous soon enoughMOREHP will become famous soon enoughMOREHP will become famous soon enoughMOREHP will become famous soon enoughMOREHP will become famous soon enough
I found that adjustng the clutch is the most frustrating thing you can do on a sporty. You go an 8th of a turn past the correct setting in the primary cover you are going to have drag or an 8th a turn off in the other direction you are going to have slippage. I spent hours the other day F ing with the adjustments.
Old 5th March 2006
a45junkie's Avatar
Master Bike Builder
mebbe his basket is notched that could cause all of the above
Old 5th March 2006
MOREHP's Avatar
Whats a notched basket?
Old 6th March 2006
cutter's Avatar
cutter cutter is offline
Sportster/Buell Model: Sportster xl883c
cutter has disabled reputation
My guess would be a bad cable and an adjustment is needed. I had that on a 77 sportster I had, and a new cable fixed it right up after it broke.
