0 Vintage sportster saddlebags?
Last Post: jordan1200
0 03 xlh 88"
Last Post: conv90
0 Hello from Minnesota
Last Post: 1HD4CJM1X4K
0 Hello from Vegas
0 Lithium battery earthx
Last Post: jharback
Last Post: toe
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 This Mikuni vm38-9 is driving me insane
Last Post: cazz1000
0 Were your parents anti bike?
Last Post: jcn59
0 New Fuel Cap
Last Post: Maaske75
0 How stock is your bike
0 Keith Black Conversion
Last Post: Scuba10jdl
0 Question on a transfer valve
Last Post: Tator
0 New England 2018
0 2004 custom
Last Post: wongjohnson
0 Quarter turn throttle tube
Last Post: Kejobe
Last Post: kmul
0 Issues with threads on some colony parts
Last Post: DirtyHarry68
Last Post: TT60
5 Favourite grips?
0 Searching for a used Ironhead, my observations
0 Sportster tachometer wiring question
Last Post: Doc308
0 09 Buell XB12 crank
0 ***DK Custom-Limited Time 10% Savings on Rock-it Shift For Sportsters***
0 What color are your pipes?
0 Front brake shorting?
Last Post: Hughieboy
0 ***DK Custom-Limited Time 10% Savings on HALF-MOON FLOORBOARDS***
jdhickm (83), Chip (70), Chief4x4 (68), willyobiker (66), CBryant (65), XLCH69 (62), sage (59), VettesRule (56), jerseyjeff (56), TheExecutioner (53), SalTheWop (53), manic_mechanic, pauldmedic16 (44), BluegrassXL (40), Superman
Old 8th June 2008
dave's Avatar
dave dave is offline
Other Motorcycle Model: FXDWG (Dyna Wide Glide)
dave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to beholddave is a splendid one to behold
Default hard to get to neutral
All of a sudden, it is very difficult to get into neutral. By that, I mean that I normally can gently pull up on the shifter (from first) and hit neutral. But now, I pull harder and harder until it finally shifts through neutral into second. Similar situation from second to neutral. Some factoids:
2004 1200 Custom, 42,000 miles
Clutch is properly adjusted
Primary oil is fresh and at the proper level
Warm engine or cold engine - same problem
Engine running or stopped - same problem
Shifting up or down (into an actual gear) works just fine
Clutch cable is lubricated and operates smoothly
I haven't checked the primary chain adjustment yet, but I seriously doubt that this could be the problem. There is no chain slap or whine, and it shifts just fine.
I feel a slight forward surge when I shift from neutral to first, which makes me think that the clutch is not completely releasing. This might be normal, though . . . I don't remember.
Is it possible that something is worn in the clutch that might be causing this? Any ideas?
Dave Funk: Lafayette, California. 2004 1200 Custom
Old 9th June 2008
Deimus Deimus is offline
Master Bike Builder
You will find interesting information in the following two threads:
http://xlforum.net/forums/s...d.php?t=168162
http://xlforum.net/forums/s...d.php?t=227842
Old 9th June 2008
dave's Avatar
Thank you. Based on this info, I will take it apart and see what's going on in there...
Old 12th June 2008
dave's Avatar
After doing some reading here, I discovered that I need a clutch spring compressor tool. Ugh. So I ordered one from J&P Cycles, and ordered a spring plate from Zanotti's (since there is a fair chance that is the problem).
My problem is a bit different, I think. With the bike in 1st gear and the clutch fully disengaged, the bike noticably wants to move. It's not enough to stall the bike though. Plus it is hard to get into neutral...
Old 12th June 2008
Then the clutch isn't fully disengaging either because of adjustment or some other problem (as you said you believe the clutch to be properly adjusted).
Old 12th June 2008
dave's Avatar
Exactly. And that is probably why it is hard to find neutral. And yes, I believe the clutch to be properly adjusted. I have done this procedure every 5,000 miles, and I understand it well. So I conclude that something is awry in the clutch itself (that will hopefully be obvious when I get it all apart).
Old 12th June 2008
YUP, sounds like it...
