Last Post: cotton1
0 Clutch cable options
Last Post: BWP 5p
0 Diagnostic help
Last Post: BradX13
0 Not charging issue!
0 Value of a Boattail?
0 Brake Squeek
Last Post: seajay
0 Cylinder Piston kits
Last Post: seajay
0 how many miles are to many miles
Last Post: Turbo Sporty 48
0 Thinking of building a custom blast...
0 Vance and Hines Code:REaD
0 Head gaskets.
Last Post: cotton1
Last Post: hexnut
0 1988 106 inch build ( agent orange )
Last Post: Will1250
0 Won't rev past 1200
Last Post: Aocasio
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
Old 19th November 2004
wickedsprint wickedsprint is offline
Sportster/Buell Model: zx-10R
wickedsprint has disabled reputation
Default stupid mistake...
we all make bonehead moves...here was mine today. I had the carb apart and was looking for the brass plug to access the idle screw...thought I saw it on the side (other bike carb has an adjustment on the side) so I was figuring this was it. I drille ditout...no dice..just a hole that leads somewhere in the carb. Found another brass plug that fits very tightly, but is not as robust as the factory one. The harley dealer was clueless since it does not come up on the parts list...it is roughly 9mm in diameter. Any idea where I can source a spare in case this one gets blown out? It is the brass plug that is facing the back of the bike when the carb is installed. Ended up drilling out the correct one on the bottom.
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
G'day sounds like ya stuffed ya carb.
WHat I think you've drilled out is one of the passage blocks.....in order to get the fuel passages in the carby they are often drilled from the outside and then blocked off.
You may have to machine a new plug up
I think you're right..I got it plugged up nicely, but I would rather use the harder metal harley part, does mikuni make our carbs or HD?
XLFREAK XLFREAK is offline
I did the same mistake. I ended up get what was left of the plug and filling it with jb weld. When it hardened I grinded it down till it looked nice and smooth and stuck it back in. Worked gets.
That's not a bad idea, thanks
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
SO glad I'm not the only idiot....
I stopped midway thru drilling, realizing what I was doing....
THEN I drilled out the RIGHT one....lol
That was about 6 mos ago....it seems ok still...
Good luck!
~Chuck
Occam's Razor...
XLF Tuning Stickies
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished road
wickedsprint,
Our carbs are made by Keihin. Stock ones can be had on Ebay pretty cheap. Hope you can get yours fixed!
Similar Threads
Stupid F'in Exhaust Stud Luckymic Sportster Motorcycle General Discussion and Problems 5 2nd May 2005 13:29
Brake bleeding, stupid question #5... engine Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 8 26th March 2005 02:59
Stupid idea / look bad? albe Sportster Motorcycle Custom Finishing 10 30th January 2005 16:25
A really stupid question. Fackler Rebel Sportster Motorcycle General Discussion and Problems 5 30th January 2005 15:00
Stupid question about controls Mechano Sportster Motorcycle Motor - Top End 22 28th January 2005 00:37
