0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Old 10th June 2008
RocchenRolle's Avatar
RocchenRolle RocchenRolle is offline
Sportster/Buell Model: XLH883 DELUXE
Sportster/Buell Year: 1988
Other Motorcycle Model: suzuki intruder vl250
Other Motorcycle Year: 2000
RocchenRolle is an unknown quantity at this point
Default cylinders question , please help
i found a pair of 883 cilinders at low cost but are they always the same for the whole EVO serie of sporty ??? thanks
ddicette frà Waltèr "E' a toj a' Sportstèr?"
Old 11th June 2008
hrg's Avatar
hrg hrg is offline
Sportster/Buell Model: 883>1200 CUSTOM
hrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of lighthrg is a glorious beacon of light
cylinders for evolution sportster from 1986 till 2003 models are same, but rubbermounts may have different cylinders and maybe bigger cooling fins
2003 XL 883>1200 Custom, Sterling silver & vivid black
Old 11th June 2008
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
I believe that is the main difference between the 04 cylinders and the pre 04 is the cooling fins they should be interchangeable as well. I know from reading numerous threads on here that the same Axtell 1250 kits are used on both so there can't be much of a difference.
Old 14th June 2008
i tried to see differences in the pics online but... they really look the same kind of cylinder... i asked this to a seller says about the conversion kit that are 2 different models, but when i asked wich are the differences he answered "sincerly i don't know... i never seen them in comparision"
i really hope they're more than similar
Old 14th June 2008
WinXP WinXP is offline
Sportster/Buell Model: Night Train
WinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enough
I put 04 883 cylinder bored out to 1200 on my 02 sportster I had. The fit is the same just 04 cylinders has larger cooling fins.
06 Night Train
95 1200 Sportster
04 1200 Sportster
09 Dyna Street Bob
