Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 13th June 2008
supr2nr's Avatar
supr2nr supr2nr is offline
Sportster/Buell Year: 1976
supr2nr is on a distinguished roadsupr2nr is on a distinguished road
Lightbulb How to Install Cam Gears in your IronHead
I just got done doing this. Here's some pictures I took for another member at another forum. I hope this helps.
1. Get the lifters out of the way. Here's how I do it.
2. Start with the pinion gear in around this position.
3. CAM 1
4. CAM 2
5. CAM 3
6. CAM 4
7. All done.
Now some of the CAMS may not look like the marks line up, but you have to get down right at the cams and look at them dead on, but you will see they do.
- Randy
Old 13th June 2008
rayzer13's Avatar
rayzer13 rayzer13 is offline
Sportster/Buell Model: 1974 ironhead
rayzer13 is an unknown quantity at this point
Damn your camra shure takes better pics than mine does.
Question? the hole in the oil pumpgear liniing up on the notch in my calmners book it has two pics one with it lined up and one with out it lined up on my bike when I'm at top dead center with the timing mark lined up my oil hole aint lined up but with one full revelution and the rear jug at tdc it is. I went with it any ways and I do have oil pressure but just wondered about this difference . Ray
Old 13th June 2008
rayzer13's Avatar
Old 13th June 2008
supr2nr's Avatar
I wondered the same thing when I pulled mine off and saw that. But if you rotate your flywheel one full rotation again the breather valve will be in perfect alignment.
Here's why:
Your breather tower is EXACTLY 180 degrees out, it is actually timed right because there are 2 breather slots in it, hence you do another engine revolution and the dot will be in the middle of the body slot, having traveled 180 degrees as it's on a 1/2 ratio same as the cams.
Old 13th June 2008
supr2nr's Avatar
Here's why:
Old 13th June 2008
supr2nr's Avatar
Originally Posted by fdny37 View Post
Randy, your screen is upside down.
Yah I know. I realized that after I had taken the pictures but not before the cam cover was back on. The screen is installed correctly just not updated right in the pictures.
Old 13th June 2008
supr2nr's Avatar
Old 14th June 2008
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enough
I'm glad they made this a sticky
Chris
Old 14th June 2008
Irondrake77's Avatar
Irondrake77 Irondrake77 is offline
Sportster/Buell Model: had an IRONHEAD XL
Irondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of lightIrondrake77 is a glorious beacon of light
I made that last pic the wallpaper on my computer
IronDrake Studios
Old 10th July 2008
73Ironheadrider's Avatar
73Ironheadrider 73Ironheadrider is offline
Other Motorcycle Model: 62 FL panhead
73Ironheadrider is an unknown quantity at this point
Chris
Your not the only one. I just removed my valve train from the heads down last night as I found the front exhaust was almost 180* off the mark. Those pic's and the pushrod adjustment sticky will help get the black widow fired up. Now I know why the motor would roll over when I tried to get the line in the window.
If I could ever find the rock that put that cam in off the mark .
