0 Who Runs Turn Signals?
Last Post: vagrant318
Last Post: Martysf
0 Slip on muffler
Last Post: Tucsonmax1
0 New From CA
0 FNG from OKC
0 New in NM
0 Stage 1 results
Last Post: 09Nightsterrider
0 Need advice (Falters When Turning Corners)
Last Post: Krjrcustom1
0 Spokes or Mags
0 -75 ironhead, My first HD
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
Old 13th June 2008
chrissenator's Avatar
chrissenator chrissenator is offline
Sportster/Buell Model: XL 1250 C
Sportster/Buell Model #2: Sportster 883 C
chrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud ofchrissenator has much to be proud of
Default 883-1250 conversion and AC...
Hi.
Hope for a little help deciding wich AC i will be pleased with on a 07 883-1250 conversion, stock heads V&H ss and a PCIIIUSB.
I am not skilled enough to see wich AC who are able to deliver enough air and same time will fit 07 EFI?.
Do i need AC support bracket?.
I have been long time into Forcewinder or simmilar but now i am not sure anymore may be a SE hamcam is ok, have a 06 SE hamcam but i am not sure if it will fit or supply enough air?
Pls help out I am lost in AC and going AC blind...
A furore Normannorum libera nos, Domine. XL1250C 07 - XL883C 03
Old 13th June 2008
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
You might try Dan at NRHS. They sell the Hurricane Flow A/C and he's a sponsor here. It should work with your setup.
http://www.nrhsperformance.com/
Sic Semper Evello Mortem Tyrannis
Old 13th June 2008
Mandingo's Avatar
Mandingo Mandingo is offline
Sportster/Buell Model: Hugger
Mandingo is on a distinguished roadMandingo is on a distinguished road
I plan on doing the 1212 conversion someday through NRHS, so i went ahead with the Forcewinder, i like the looks and i know it definitely gets plenty of air
2003 Hugger 883
Santee Shooters 45 Caliber Staggered Duals, Forcewinder AC, 45 pilot, 170 main, 88 needle, drilled slide, 2 1/4 turns out, Iriduim plugs
Old 14th June 2008
So wich Forcewinder fits a 07 EFI, and there are two Forcewinders i think, there is an XR2 or something? Finaly i have seen something about a modification to the Forcewinder done with a Dremel and some stated that it is only for new models Forcewinder?
Thanks for ansvers..
Still I feel like I just arrived eart!!
Old 18th June 2008
Anybody who knows wich Forcewinder to fit a Sportster 07 C ?...
Old 18th June 2008
The XR1 is the one you want. We sell them for $210 and you will also need a breather kit to go with it.
Old 19th June 2008
Thanks a lot Dan..
