Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
carb, cv carb, fuel
Old 13th June 2008
NC_REDNECK_1981's Avatar
NC_REDNECK_1981 NC_REDNECK_1981 is offline
Sportster/Buell Year: 1988
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1984
NC_REDNECK_1981 is an unknown quantity at this point
Default help me figure this out please
im new to this forum so dont bash me to hard please. i have 1988 1200 sportster with a stock engine. i bought this bike a cpl months ago and it already had drag pipes on it and averaged about 80 miles to the tank(2.2). well i installed a se air cleaner with a k&n filter and installed 45/175 jets as i was told by the stealership. the bike runs great but ionly get about 45 miles out of the tank. can anyone help me out and tell me what is wrong?
Old 13th June 2008
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
look around at other 1200's. that mileage is about par with that setup...
Old 13th June 2008
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
He said 45 miles to the tank not per gallon. That mileage is much too low. Check your plugs to see if your running overly rich. Also double check to see if your leaking any gas from your petcock or gas lines. Are you losing gas after shutting the bike down thru the overflow?
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 13th June 2008
i used to see gas dripping a little bit when i first started the bike but that doesnt happen anymore. the other night i accidentally left the petcock on all night and i didnt see any gas on the ground the next morning. if its running that rich wouldnt i see black smoke out of the pipes? i have no knowledge of a cv carb at all. i can work on cars but ive never worked on a motorcycle.
Old 13th June 2008
if imy plugs say its to rich how do i lean it down? with the factory jets and the se ac and pipes it was way to lean. the plugs were bone white and wouldnt take any throttle
Old 13th June 2008
wilbur's Avatar
Wait...What?
OMG how did I overlook that? Yes, 20 mpg is a little to low! If the gas isn't dripping out, make sure your float is OK and not "running" into the engine. Plug check also.
Old 13th June 2008
Terp84Alum's Avatar
Terp84Alum Terp84Alum is offline
Sportster/Buell Model #2: Yamaha Raider
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 2008
Terp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to behold
Is someone stealing your gas?
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
Old 13th June 2008
wilbur's Avatar
Wait...What?
Are these new plugs?
Old 13th June 2008
biknut's Avatar
biknut biknut is offline
So you're saying you're only getting about 23 mpg? If that's the case something is very wrong.
I guess you know it won't run very well at low speeds with open drag pipes. That's probably not your problem though. 88 model 1200s came with 200 main jets from the factory. The stock CV carb didn't have an accelerator pump. I hope it doesn't still have the stock rubber intake manifold. If so it's worn out.
My bike, also an 88 model, got well over 50 mpg set up like your bike except with stock headers and SE mufflers.
Tell me more about your bike.
Old 13th June 2008
SpringerSam's Avatar
SpringerSam SpringerSam is offline
Sportster/Buell Year: 70
Sportster/Buell Model #2: Softail Springer
SpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished road
Welcome to the forum...
Go back to the original components one at a time...find out which change affected the mileage. It seems almost unrealistic to cut your mileage in half.
Sam
