Last Post: conv90
Last Post: groovemeisterus
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Old 15th June 2008
Mattbastard's Avatar
Mattbastard Mattbastard is offline
Bike Builder
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: V-Strom 1000
Other Motorcycle Year: 2014
Mattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of light
Default Conversion w/ N4's is noisy
Now I've heard the SE bolt in cams are a bit more clattery, but this sounds like piston valve contact here. What I have is .020" over Wiseco 10:1 conversion pistons, SE .497" cams, stock 883 heads with an NRHS competition valve job, and a 1200 ignition module. As soon as I fired her up I got some clatter, which could be mistaken for piston/valve contact. When I put it together after I waited for the lifters to bleed down I spun the motor and had no contact. Also, when I did a conversion before with the same stuff I used JE pistons and there was plenty of clearance, so I didn't check this time.
My question is: has any of the forum heard of my combo having problems with valves hitting the piston? I used stock HD gaskets in case this matters. I know they're thicker than the Cometic gaskets.
Thanks
Old 15th June 2008
Bike Builder
False alarm folks, nothing to see here!!
It was pinging. I had the timing too far advanced for the new CR. I just backed the plate off a bit and fired it back up and the "knocking" is gone.
Boy them cams is rattly though.
Old 15th June 2008
rottenralph's Avatar
I switched from n8'2 to SE536 this year and I was quite surprised at how quiet the higher lift cams are. I suspect the ramp design has something to do with it. I can do without the clackity clack of hed noise.
Old 15th June 2008
Bike Builder
You still on the fence about selling me those N8's?
Old 15th June 2008
They are long gone, I think you are talking about the SE536. I won't convert to turbo till fall. I am not sure how that is gonna go so most likely they will go in a box for a while till I am sure the motor is not going to grenade or warse, not start.
Old 15th June 2008
Bike Builder
If I were you I'd go back to stock cams with a turbo. Forced induction loves no overlap cams.
Old 16th June 2008
That is the plan. I just happen to have my original cams on the table.
Old 16th June 2008
Bike Builder
Soooo........
whatcha doin' with the 536's?
Old 16th June 2008
ReddTigger's Avatar
Originally Posted by Mattbastard View Post
Soooo........
I think he has a waiting list for them already
States I've Ridden in
71.3 hp 70.8 tq
Old 16th June 2008
They will be waiting in a box till I know the turbo is on for good. That may be never. In the same box will be my dyna 2Ki, supertrapp, S&S super E, and more.
