0 Fuel Pump Problems
Last Post: Blues
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: ss396
0 first engine start after rebuild
Last Post: Sprtstr1200s
0 Shovelhead forum gone?
Last Post: gpydeski
Last Post: JensWest
0 Did I buy the wrong length chain?
Last Post: 83XLX
Last Post: Heff
Last Post: BILLETPROOF
0 New England 2018
Last Post: The Crusher
Old 20th March 2006
rossie rossie is offline
Sportster/Buell Model: M2
rossie has disabled reputation
Default SE 32942-02 nose cone Ignition module
Hi,
just wondering if anyone is running a
Screamin Eagle 32942-02 nose cone Ignition module.
I am thinking of putting one in my M2 buell motor as i think the stock one has died.
Any info on whether this unit is good or bad would be greatly appreciated.
They are selling for around US$100.00 on Ebay, which is about half the price of other brands on the market.
Is this cos there shit or is it a bargain.
thanks in advance
Rossie
Old 23rd March 2006
ritchieb's Avatar
ritchieb ritchieb is offline
Sportster/Buell Model: 883R
Sportster/Buell Model #2: M2 Cyclone
ritchieb is an unknown quantity at this point
I bought one off of Ebay and am planning on using it on my '02 883R which now has Thunderstorm heads and NRHS Hurricane pistons.
I have looked for other people's experiences with this ignition but haven't found anything. It looks like I'll be blazing my own trail on this one.
If you've found out anything, if you don't mind, please let me know.
Old 25th March 2006
Hi, I have found nothing to say whether the unit is bad or good.
I found a site that said the unit is made for SE by crane and is the same unit as the crane hi4.
If you compare the two units they do look the same except for the name printed on them.
I think we have got ourselves a bargain.
I myself like the fact that once i start the engine mods once the bugs are sorted out i can just change the mode to match the upgrades without pulling it to bits again.
Have you already got your unit?? mine wont be here for a coulpe of weeks i think.
Any chance you can post or send me a scan of the instalation instructions that came withit.
I would like to get everything ready for when it turns up.
good luck with your project, NRHS make some good bits, thats were i will be putting my order in at.
Ben
Old 25th March 2006
Hi.
I am currently run one in My 2003 883/1200.
I only have a couple hundred miles on it, and so far it seems to be all i hoped for, but i have not finalized the Dial in, so it's a wait and see at this point.
I do like how easy it is to adjust...seems to run good, but the engine is still on the break in, so it's kinda hard to give a full opinion.
I will just say that i do like it.
Old 25th March 2006
dabronco's Avatar
dabronco dabronco is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH (ironhead)
Sportster/Buell Year: '77
Other Motorcycle Model: Sold it!!
dabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura about
I wonder if it could be adapted to an Ironhead.
Old 3rd April 2006
ritchieb's Avatar
Default Re: Update Installed Harley Adjustable Ignition!
I received my ignition module on Friday and installed it today. Actually pretty easy. Currently I have it set on Curve 8...started with Curve 5 but response was very slow. I'm taking it easy...still breaking it in (Thunderstorm Heads & NRHS 1212 kit)
Old 10th July 2006
Ray Kimbro's Avatar
Ray Kimbro Ray Kimbro is offline
Sportster/Buell Model: XLH 883/1200
Sportster/Buell Model #2: XLH883/1340
Sportster/Buell Year #2: 95
Ray Kimbro has disabled reputation
Does anyone know the pinouts for the programming cable? P/N for the Crane or HD software/cable kit?
Old 1st August 2006
mrgraphic mrgraphic is offline
Sportster/Buell Model: 1200 XL
mrgraphic has disabled reputation
Default Need Pinouts?
Pinout for XL app. Mod # 32942-02.. Mod works with Buel Blast @ diffrent pinouts than below.
This pinout is for the XL Dual Fire (not single fire) Coils such as coil #3165-97
Replace the single fire stock coil before proceeding if you have it.
This pinout is not for the 1200 sport dual plug system.
Pin #1 wht/blk = Ignition swt.
Pin#2 violet/white = VOES
Pin#3 violet/org = not used
Pin#4 pink = Coil/Tach
Pin #5 grn/gry = Bank-angle sense
Pin #6 pin plug = Grnd. not used
Ride safe
Old 1st August 2006
My bad...thats the mod. connection pinouts. Still working to get the 8 pin din and what protocal and software if available.. So far its a factory test plug only.
Old 18th August 2006
ritchieb's Avatar
Default Screamin Eagle 32942-02 Ignition Module Died!!
Well I've had this module installed since April and I think it has died. Once my Sportster has been ridden and then let to sit for 30 minutes it won't start.
You have to turn on the ignition switch, wait 15 seconds for the status light on the module to light, then it will start. If you don't wait for the status light it won't start.
As the bike cools off the 'wait time' for the status light gets shorter and shorter. I never would have figured this one out if I hadn't taken the nose cone cover off to look for the status light.
Apparently 'heat soak' is slowly killing the module. Now I'm probably in the market for another brand of ignition module because I'm suspicious of how well designed this module (SE/Crane) is.
If you guys think this is just a fluke please let me know. Hopefully quite a few of you are running this module and can speak to this.
2002 883R
NRHS 1212
Thunderstorm Heads
2:2 SuperTrapp XR Style
