Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Old 25th June 2008
oliver81's Avatar
oliver81 oliver81 is offline
oliver81 is on a distinguished roadoliver81 is on a distinguished road
Default Single Fire set up
I have an 03' 1200xlc. stage one. I took off my cam cover to chop it ( going for the bober look) and broke the Ignition module. I was thinking about upgrading it. Is the Accel single fire "super System' 1970-99 a good set up to get? any advice would be great! http://cgi.ebay.com/ebaymotors/ws/eB...m=230263331070
myspace.com/bobbyo81
Old 26th June 2008
Mattbastard's Avatar
Mattbastard Mattbastard is offline
Bike Builder
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: V-Strom 1000
Other Motorcycle Year: 2014
Mattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of light
Single fire is no different than the system you have.
DUAL fire is better.
Old 26th June 2008
oliver81's Avatar
Thanks Mattbastard!
Old 26th June 2008
Terp84Alum's Avatar
Terp84Alum Terp84Alum is offline
Sportster/Buell Model #2: Yamaha Raider
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 2008
Terp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to behold
Wow. This is the first time I've heard this. Tell me why you think this. My understanding was that dual fire was HD's cheap work around.
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
Old 26th June 2008
oliver81's Avatar
Ken have you changed yours to a single fire?
Old 26th June 2008
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
Single fire is better. I run Dyna 2000i
Old 26th June 2008
Kwest187's Avatar
Kwest187 Kwest187 is offline
Sportster/Buell Model: 883/1200 standard XL
Sportster/Buell Year: MUTT
Kwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really nice
I recently changed from stock to SE's selectable curve ignition module along with a SE single fire coil...I like the change...bike runs smoother, warms up faster, I can adjust my Ig. timing to suit my riding in a matter of minutes (you can adjust to four different curves to suit you and your bike...the fastest curve is a bit hard on my bike) I did have to mod my coil bracket b/c the SE coil is larger and would have rested on my front cylinder head...also I recommend buying a multi-use plug wire kit and making your own plug wires b/c I found out after the fact my SE front plug wire was to short by about a 1/4 inch...I bought the entire set-up off ebay (new) and it cost me under 150 bones...shop around, check the forums...FE gave me some good advice when I had some of the same ?'s you do-
oh yeah and now I can pull my front tire off the ground pretty easy (in 1st and 2nd) with quick blip of the throttle...no bogging, very responsive-
The horizon will never come into focus-but that doesn't keep me from trying.
Old 26th June 2008
oliver81's Avatar
150 bones ? Wow thats alot cheaper!
Old 26th June 2008
XLinAL's Avatar
XLinAL XLinAL is offline
Riding with Angels
Sportster/Buell Model: Chrome Yellow XL883>1200C
XLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enoughXLinAL will become famous soon enough
I like single-fire better.
Get an adjustable unit like the Twin-Tec 1005S.
The only thing w/ single-fire ignition, you have to get a single-fire coil too.
Richard
2001 XL883>1200C
"Dream as if you'll live forever, live as if you'll die today"
- James Dean
Old 26th June 2008
JonnyRtn's Avatar
JonnyRtn JonnyRtn is offline
Sportster/Buell Model: 1200 conversion
Sportster/Buell Model #2: FLH
Sportster/Buell Year #2: 1971
Other Motorcycle Model: FLHTC
JonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura about
+1... I run a Dyna single fire..
Bolting foo foo on... is not building.... The dealer is not your friend, he is like the IRS, just wants your money.... Chopping up perfectly good motorcycles is fun, try it, you might like it...
