Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 LePera Kickflip
Last Post: icebob
0 What's your helmet?
Last Post: Grymy
0 what do you think of these plugs?
0 A Day in the Life...
0 2016 48 Hesitating
Last Post: XLXR
0 'Idiot Lights' plastic face
Last Post: Edster
0 Cartridge Conversion?
Last Post: XLXR
0 Flirting with death
0 Tried to buy a new helmet
Last Post: kap
0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Old 8th April 2006
VisualFeast's Avatar
VisualFeast VisualFeast is offline
Sportster/Buell Model: V-Strom
VisualFeast is an unknown quantity at this point
Unhappy Taxes paid... dissapointing
SEII slip-ons, SE a/c (newer 29044-04B design), and rejet kit. Dealer did all the install & rejet.
Now there is less power up until almost full throttle, and now the engine will sometimes keep running a few seconds after I shut it off. Also, after it warms up, when I come to a red light/stop sign, it will idle too fast for 30-seconds to a minute, then will settle down to normal idle speed.
So I called the dealer and scheduled an appointment. He agreed it didn't sound right and wanted to take a look at it.
Are there any pointers I should keep in mind? Should I take the rest of the rejet kit with me when I drop it off?
Old 8th April 2006
rottenralph's Avatar
sounds like it needs the carb adjusted properly. Dynojet to the rescue. Jets are good but the kit addresses more than just idle and main jet. When it is right you will know it.
Old 8th April 2006
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Dealer fubared your stage 1 take it back and make them fix it right the 2nd time, free of charge for you.
just cause they are a H-D tech don't mean they have a clue what they are doing.
RTFS
Ride That F'N Sportster!!
Old 8th April 2006
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Yes...
Since the dealer did the work, he'll fix it..
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 8th April 2006
daesdaemar's Avatar
daesdaemar daesdaemar is offline
Sportster/Buell Model: 1200 XL Custom
daesdaemar is on a distinguished roaddaesdaemar is on a distinguished roaddaesdaemar is on a distinguished road
I think it's a universal truth that a stage 1 done right definitely noticeably improves the performance. If not, something got done wrong...
Old 9th April 2006
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Is it HD of Greenville?
If so, grrrrrrrrrrrr.
Make 'em make it right. Sorry, but I haven't heard anything good about them....
Old 10th April 2006
Yeah, it's the H-D of Greenville... about 1 mi from my house!
Old 10th April 2006
TiBaal89's Avatar
TiBaal89 TiBaal89 is offline
Sportster/Buell Model: 1250 Custom
TiBaal89 is on a distinguished roadTiBaal89 is on a distinguished roadTiBaal89 is on a distinguished road
Wow, that s. I have SEII's, A/C, and rejet.... it was an excellent improvement! There is something seriously wrong here....
-Mike ('04 1250C, RIP)
Old 11th April 2006
Is there some way I can look at the spare pieces left from the jet kit, and tell what jets they have put into my Sportster?
Old 11th April 2006
Trout's Avatar
Trout Trout is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: XS650 Bobber
Other Motorcycle Year: 1979
Trout has disabled reputation
If your "kit" is a DynoJet kit, then yes, you should be able to tell, at least for the main jet. The kit comes with a 160, 170, 180, and 190 main. See which one is missing.
The DynoJet kit doesn't come with a pilot jet, because you don't necessarily need a larger one with their needle.
The "real" information you need to find out is which slot they put the clip on the needle jet. You have to remove the slide to see where the needle is set. I'll bet a buck they just slapped it on wherever... probably way too rich judging from your description of the problem. When I took mine off after I bought the bike, the needle was set too rich. I took my friends off (Wide-Glide) a few months ago and his was set too lean. The DynoJet instructions are VERY specific about where to set the needle.
In my tinkering, I've learned that the needle has a much bigger impact on the overall picture than either the main or the pilot jets.
If it were me, I'd buy a manual and learn to do it yourself, even though the dealer owes it to you to get it right. The fact is, they may NEVER get it right.
If you can follow written instructions, have a little patience, and can operate a screwdriver, then you can successfully tune a CV carburetor. For some reason, there are a few Harley Certified Mechanics that can't pull this off.
