Last Post: BluBeaSSt
Last Post: jcro61
0 90 in. Build
Last Post: mac93
Last Post: 883openpipes
0 New England 2018
0 Forty-Eight Special and Iron 1200 Sportsters announced today
0 Sportster or Street Bob
Last Post: seagullplayer
Last Post: conv90
Last Post: hscic
Old 10th April 2006
Confused89's Avatar
Confused89 Confused89 is offline
Sportster/Buell Model: Had a 1200 XL
Other Motorcycle Model: FLHTP Electra Glide
Other Motorcycle Year: 2011
Confused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud of
Question Speedometer Question
I don't know how to say this but when I went to zero my odometer the other day I apparently forgot to wait until the milage showed up. That one little time period where it shows some wierd numbers and letters on you odometer. Anyway I pushed the button in before I was suppose to and found that the letters and numbers go all the way up to ten so I am guessing it is some kind of program that you can gain acess to from the odometer. After it went to ten it said something else and then went back to one. I have no idea what it could have been or what effect it could have on the enigne, but it was a little hard to start after I did this. Does anyone have a clue as to what it does or what it is?
I am that socially awkward moment.
Old 10th April 2006
DustyJacket's Avatar
DustyJacket DustyJacket is offline
Sportster/Buell Model: BMW R1200RT
Sportster/Buell Model #2: Buell Blast (Purple) P3
DustyJacket will become famous soon enoughDustyJacket will become famous soon enoughDustyJacket will become famous soon enoughDustyJacket will become famous soon enoughDustyJacket will become famous soon enoughDustyJacket will become famous soon enoughDustyJacket will become famous soon enough
Those are the diagnostic codes.
When you turn your bike back on, all should be normal.
Old 10th April 2006
Confused89's Avatar
Thank you for your answer.
Old 10th April 2006
Here is more than you ever wanted to know:
http://www.harleyhog.co.uk/0405troublecodes.htm
Old 10th April 2006
Moved On Moved On is offline
Those codes are for a rubber mount. The codes in Confused89's bike are different since he has an '00.
Gazza
