0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
Old 9th February 2005
bamf_shadow's Avatar
bamf_shadow bamf_shadow is offline
Sportster/Buell Year: 1976
bamf_shadow is an unknown quantity at this point
Default How to lace a 40 spoke wheel?
I just got a new 21" rim and a set of spokes fer my 76. I will be using the stock spool and the rim is advertised to lace just like the stock setup. Anyone know of a site with a how to fer this? I can see myself getting very frustrated without some help. Thanks!
collinsb's Avatar
collinsb collinsb is offline
Sportster/Buell Model: Custom 1200
collinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura about
Bamf,
Try here http://http://www.rickadee.net/~zeph...35/ad4935.html
and here:
http://http://www.sheldonbrown.com/wheelbuild.html
here's another:
http://http://www.ehow.com/how_14174...ike-wheel.html
Let us know if it helped!
Billy
Oh Yeah!
My motorbike is better than your motorbike!
My dad can beat up you dad!
Yo momma!
HrdlyDangrs's Avatar
HrdlyDangrs HrdlyDangrs is offline
Other Motorcycle Model: Yes
HrdlyDangrs has disabled reputation
If you've got a Factory Repair Manual for your bike, you will find all the info on how to lace your front wheel in Chapter "Wheels" page 2-12.
Be sure to follow the directions for your year front hub which is 1973 and later if your front hub is a Disc hub.
If your running the earlier drum,the info is on page 2-15.
I've laced and trued several wheels and they're not hard to do, but you must follow the instructions for the placement of the Short and Long spokes and the required number of spoke 'cross over'. If you have your 19" front wheel intact, use it as a referance.
After you get it laced and the hub centered in the wheel, your going to need some type of truing stand. Trueing will take some time to get right if you've never done it before.
If you have a problem or no truing stand, then you can take to your local shop and let them true it for you. You will have saved some money by lacing it yourself....so long as you laced it correctly to begin with.
Similar Threads
Front Wheel Rubbing on Fender ... IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 6 3rd April 2005 12:36
Rear Wheel for 99 Custom Henry89 Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 7 19th March 2005 00:53
Mick's Winter Project, crudy spoke wheel IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 6 24th December 2004 02:25
Polishing Aluminum Parts IronMick Sportster Motorcycle Custom Finishing 21 12th December 2004 04:38
