0 Brake cable on 72 xlch forward controls
Last Post: Jamesripley
0 Shotgun Porn
0 my '82 XLS Roadster project
Last Post: N-Rico
0 Let's See Them R's!!
Last Post: grako122
Last Post: Skuzeee
Last Post: vagrant318
0 The forum got talent
Last Post: Skuzeee
0 900 heads contd..
0 Oil and smoke everywhere
Last Post: fbroos73
0 65B genr8r I hecked up
Last Post: Kaptain
0 attn DR DICK
0 Fixing a loose mirror
Last Post: Yochstein
0 Timing after dynatek 2000i install
Last Post: jordan1200
Last Post: felis
0 Timing issue
0 Can’t get upper triple tree removed. Advice?
Last Post: speedfoos
0 Oil pump working, no oil to rockers
Last Post: shovithead
0 project 74 sporty
Last Post: the cowboy way
0 Aligning ‘14-newer OEM exhaust?
0 Front brake combination not working well. Suggestions?
0 JACKHAMMER 570 Cams!
Last Post: md1200
0 Do you run MAXIMUM PSI?!?
Last Post: Edster
0 loose needle bearing in cam chest
0 My oil changes just got easier
Last Post: Tucsonmax1
0 ‘68 XLCH...transmission
Last Post: chevelle
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
Old 16th April 2006
shotgun46's Avatar
Default battery issues
well when i got the bike they told me they put a new battery in it ( dont look new ) when they dropped it off the battery was dead so i charged it then installed a battery tender every time i ride i plug it back in and it takes longer to charge so how can i test it other than taking it to the local auto zone and have a load test done ?? its been on the charger for 24 hours and still charging at 5 amps ?? thanks !!
Sportsters Rule ! :banana
Old 16th April 2006
shotgun46's Avatar
any one here today ??
Old 16th April 2006
XLFREAK XLFREAK is offline
here...but drinking. not tech time for me
Old 16th April 2006
arent these newer batteries agm? i dont know if you can do a hydrometer test. someone will answer soon.
Old 16th April 2006
shotgun46's Avatar
hey it s all good i drank too much last night so have a couple for me will ya !!!!
Old 16th April 2006
i never disobey that order!!
wish i could be more help but i havent a clue as i havent run into a battery problem...yet.
Old 16th April 2006
wabiker's Avatar
wabiker wabiker is offline
Sportster/Buell Year: 94
Other Motorcycle Model: FLSTSB Crossbones
Other Motorcycle Year: 2008
wabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to beholdwabiker is a splendid one to behold
Sounds like its time for a new one. How old is it?
Support Your local B.A.C.A -Bikers Against Child Abuse
Old 16th April 2006
sayed supposedly new
Old 16th April 2006
wabiker's Avatar
*Supposedly* is the working word. If it is a sealed Bat, ya cant use a hydrometer. If it aint sealed, 1 or 2 dead cells or nearly dead cells will give ya troubles. Autozone load tests are free.. Save a whole bunch of head scratching and trouble shooting if he just takes it in..... thats what Ive always done.
Old 17th April 2006
If you are charging the battery at 5 amps you have killed it. No motorcycle barttery should ever be charged at more than 2 amps. The preferred chargers are the automatic ones between .75 and 1.5 amps, like Battery tender or Battery Minder, or other similar ones from auto parts shops. These either shut off or go into a maintenance mode when the battery is fully charged.
A cheap load test is to fully charge the battery then, with the plugs disconnected and a voltmeter attached to the battery, crank the starter for 10 seconds [no more!]. If the reading goes below 10 volts the battery is toast.
