0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Last Post: felis
Last Post: Skwerly
Old 14th July 2008
aussiesport's Avatar
aussiesport aussiesport is offline
aussiesport has disabled reputation
Exclamation torque settings for sprocket bolts?
hey guys n girls does anyone have the torque setting for the wheel sprocket on a 98 im guessing it wouldnt be too tight in alloy and all, around 40-50 ish?!?!?!
''ride her till she breaks"
Old 14th July 2008
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
For a 2000:
cast wheels 55-65 ft/lb
laced wheels 45-55 ft/lb
[SIGPIC][/SIGPIC] AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
Old 14th July 2008
heya gaz thanks mate im gunn ahave to buiy a dam manual i think lol..hows things traveling your way ?
Old 15th July 2008
Bike's running really well after I tuned and timed it myself with an LM-1 air/fuel meter.
Old 15th July 2008
jolly good to hear mate,i cant wait to get this dam thing going again im haven withdrawwwwlllllssssssssss! ..stay safe bud we have had a lot of bike deaths and accidents up here over the last few weeks starting to get real bad for bikers .but cant let the cages win
Old 15th July 2008
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
My service manual says (1993 & 1994):
For cast wheel use red loctite and tighten bolts 55-65 ft lbs.
For laced wheel use red loctite and tighten bolts 45-55 ft lbs.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 16th July 2008
mrbreezeet1's Avatar
mrbreezeet1 mrbreezeet1 is offline
mrbreezeet1 is on a distinguished roadmrbreezeet1 is on a distinguished road
I've always just used blue, and it's been fine.
Tony
Old 16th July 2008
hey breezey i dunno wot the diff is but i think blue stays a bit plyable ?!
Old 16th July 2008
Yes the blue is a medium strength ,the red you may need heat to separate.
But maybe there considering the heat from the rotor.
Blue was just what I had on hand, and never had it loosen up.
Tony
Old 19th July 2008
sweet mate
