Last Post: rickmodee
0 1967 XLCH stroker project
0 79-83 dual disc fork spring length
Last Post: Reverend G
0 New to Harley
0 Check engine light, again
Last Post: lazyb8s
Last Post: T^2
Last Post: Smerch
0 Curious as to what I actually have
Last Post: JakRabbit
0 Not charging issue!
Last Post: r4fthrs
0 Running Rich
0 Head gaskets.
Last Post: Sadsack
0 spoke nipple tool?
Last Post: Bayou.Ogre
Last Post: jammantoo
Last Post: robbie202
0 1977 Bright Blue
Last Post: Larry May
0 Stock 883 cold blooded
Last Post: seagullplayer
Last Post: jordan1200
0 rpm jump pulling in clutch
0 Value of a Boattail?
Last Post: valvebeater
0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
Old 21st April 2006
ricodelfuego's Avatar
ricodelfuego ricodelfuego is offline
Other Motorcycle Model: Yamaha RD400
Other Motorcycle Year: 1977
ricodelfuego is an unknown quantity at this point
Default taking carb off bike?
is it necessary to take the carb off the bike just to change to 42 jet to a 45?
thanks in advance - rico
the nogs - purveyors of fine donkey rock since 2001
nogturnal.com
Old 21st April 2006
xena's Avatar
xena xena is offline
Assistant Administrator
nope. you can do it on the bike. Lots of folks here have. I'm sure some of them will chime in.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 21st April 2006
GOTWA's Avatar
GOTWA GOTWA is offline
GOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enough
Sportster Girl had a real good pic of how to do that.
Old 21st April 2006
hybriDatsun350's Avatar
hybriDatsun350 hybriDatsun350 is offline
Sportster/Buell Year: '99
Other Motorcycle Model: Not yet!
hybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enough
It's alot easier just to take the carb off of the bike. Most people think its a big chore, but its really not that bad. With the carb off of the bike you get a better look at everything, and you can do a better job of cleaning. It's just a couple of vacuum hoses, some throttle cables, a fuel line, and a couple other small things. Its really not that bad, but I suggest that you go buy a HD service manual if you dont already have one!
Nick
1999 XLH1200, Vivid Black....Trimmed cam cover, Thunderheader, Ram Flo 400, Pingel petcock, forward controls, black drag bars w/4.5" pullback risers, relocated front turn signals, Progressive fork springs, 4-piston HD front caliper, and a bunch of black powdercoated stuff!
[U]Click to Enlarge[/U]
[URL=http://www.putfile.com/pic.php?img=4504798][img]http://img1.putfile.com/thumb/1/1212393091.jpg[/img][/URL]
Old 21st April 2006
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Hey rico, you can leave it on. You will need a 90degree #2 Phillips screwdriver to get the bowl screws off. I would replace them with socket head allens when you replace the bowl. The stock screws are junk.
Here's a pic with the bowl off:
You will also need to drill and pull the SILVER colored mixture screw cap. NOT the brass plug. You can drill a small hole with a drill (like a stubby bit in a dremel motor) then screw a small sheet metal screw in the plug and twist it out. This will give you access to adjustment your mixture.
Old 21st April 2006
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
All it takes is a tap on the float to give you more problems than you bargained for...
Take it off...clean it while you're at it.....
Getting to the mixture screw is the tough part...
I've had my carb off DOZENS of times, but I STILL don't work on it, on the bike...
For JUST a pilot jet change...I might....but not the first time I ever did anything to it....
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 22nd April 2006
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
no ... I don't remove the carb for jet changes... and prefert o remove the tank to do needle adjustment...
As the rubber ring that the carb sits at the inlet manifold tends to get a set in it and if it's over 6 months old will often require changing.....
To keep removing and replacing the carb without changing the rubber ring is a recipe for problems...
HOWEVER...... it's a good idea to remove it the first time to give you a better view of where everything is.... just replace the rubber if it's over 6 months old or feels hard or shows an indent from where the carb sits .. and use a bit of silicon grease on it when ya put the carb back in....
Old 22nd April 2006
IMO it is a bad idea for a carb newbie to work the carb in the bike. It is an easy job to remove it. There is the float system which can easily be disturbed. There are the jets etc that are made of brass == soft. There are bolts and jets which may be very difficult to remove. This all calls for working on the bench.
To repeat: IMO it is a bad idea for a carb newbie to work the carb in the bike. It is an easy job to remove it.
