0 900 dual carb front head
Last Post: thefrenchowl
0 Clutch issue
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 little rock
Last Post: tedg
0 New acquisition
0 brake lever for master cylinder.
0 Ignition question
Last Post: Anti-Hero
5 Summer time heat
0 79 Tranny
0 R.I.P. Arlen Ness
Last Post: oupa
Last Post: moparnut72
0 Have you taken your “dumbass pill” today?
0 883 to 1250 is done
0 883N brake/signal problem
0 I'm going nuts (Adjusting Fuel Mixture)
0 How long for the XL Member patch?
Last Post: bdawson
0 mid controls
Last Post: whetrick1
Last Post: farmall
Last Post: Lone Rider
0 Front cylinder noise
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
mike, Rick572 (72), Tailchaser (71), Back Road (55), sanman12002003 (54), LilMsRida (54), wargod1 (50), tplyons (32), DOM! (31)
Old 1st August 2008
hawk mechanic's Avatar
hawk mechanic hawk mechanic is offline
Sportster/Buell Model: XR1200
Sportster/Buell Year: 09
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 74
hawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nice
Default compensating sprocket removal
To keep it short and sweet, I got the nut off of both sprockets. I thought that would be the worst part of it, but I guess that I was wrong. The clutch basket wants to slide right off, but not the compensating sprocket
I am about to make some sort of a slide hammer and pull the thing off. My plan is to put two holes into a piece of steel for the holes in the sprocket holes. In the center, I am going to drill a hole, and use my home made slide hammer to try to pull it off. Somebody please tell me if that sounds like a horrible idea. I will see if it all works tomorrow.
Joe
'09 XR1200, '74 Ironhead
Old 1st August 2008
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
You could also use a 3 1/2 - 4 inch X 1/2" bolt having fine threads for most of its length and use the nut on the inside of your steel cross piece to gently pull the sprocket off the crankshaft.
Both ways work one is just slower and easier on the main bearing.
Cheers;
