0 Won't rev past 1200
Last Post: Aocasio
0 Engine dies when choke off
Last Post: ChicagoSlim
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
Last Post: halfmt1
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 newby from Australia
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 too bad
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
Old 4th August 2008
Saltydog's Avatar
Saltydog Saltydog is offline
Saltydog is on a distinguished roadSaltydog is on a distinguished road
Default Tools needed for shock removal
What exact tools do I need to remove my rear shocks?
Old 4th August 2008
Thornhammer Thornhammer is offline
Sportster/Buell Model: 883C Pewter Pearl (gone)
Other Motorcycle Model: SuperGlide Custom
Other Motorcycle Year: 2009
Thornhammer is on a distinguished roadThornhammer is on a distinguished roadThornhammer is on a distinguished road
T-50 Torx bit and a 3/4" wrench, I believe. There isn't a lot to it.
A bike lift is a B-I-G help, assuming you want to get the darn things back on again after you've removed them.
That or some method to compress the shock springs.
Caved to the little devil on my shoulder. Traded the Sportster in on an FXDC.
Old 4th August 2008
MadMax25's Avatar
MadMax25 MadMax25 is offline
MadMax25 has disabled reputation
Firstly, do only one at a time!!!
Having said that, doing one at a time will still allow
for a little bit of misalignment making getting the bolts
back in through the shock eyes very tough.
Don't ask me how I know.
You will need some way to jack up the swing arm
to get everything back into alignment.
Any ride is a good ride, when you and the scoot
make it back to the garage, in mostly large pieces.
MadMax25
Old 4th August 2008
XLXR's Avatar
XLXR XLXR is offline
Use the 3/4" wrench to turn the nuts, use the torx bit to hold the bolts from turning. If you use the torx bit to try and turn the torx bolt to loosen the nut, it will likely strip. It is almost insane to try and change shocks without jacking up the bike enough the get the rear wheel off the ground. After I jack up the bike, I use a wooden ramp, similiar to ramp you would drive a car up on to work under it, to slide under the tire and get the mounting holes to line up. Use lock tight.
Old 4th August 2008
blkshark's Avatar
blkshark blkshark is offline
Senior Bike Builder
blkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to allblkshark is a name known to all
Glad I stumbled on this. I assume the same size torx applies to an '07? I've been thinking about pulling the rear shock, too. Not to change (at least yet) but to paint the coils black. Just think it would look better. Glad to hear it isn't too big a deal. Not in any hurry to do this, but its something I've been pondering.
Thom
Old 4th August 2008
XLXR's Avatar
It can turn into a nightmere if you try and do it without a bike jack or if you strip the torx bolts.
Old 4th August 2008
Yeah 07's are still T-50s.
I've not stripped a Torx bolt since the mid-90s.
The forumula to prevent that is
1. Make sure you have decent bits.
2. Make sure you have the right size.
3. Put bit on an extension, put combo in bolt and wack it with a hammer to help free any corrosion or threadlock
4. Put pressure inward on the bit (downward on the head of the ratched or breaker bar) as you loosen it.
I've swapped a bunch of shocks without lifting the bike - as long as the replacements are the same length or shorter - but if they're longer it's a LOT easier to jack the bike up a bit first.
Kev
Old 4th August 2008
powellsanmiguel's Avatar
powellsanmiguel powellsanmiguel is offline
Sportster/Buell Model: XL 833C
powellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enough
Default Bike Lift
Remember too, that a bike lift can be as simple as this:
http://www.nightrider.com/biketech/bikelift.htm
And do replace the shocks one at a time. It helps a lot.
Your motorcycle is like your toothbrush, but it hurts a lot more if you drop it on your foot.
Old 5th August 2008
blkshark's Avatar
Senior Bike Builder
What about a regular automotive rollaround floor jack? Will that work? Maybe with a larger platform?
Old 5th August 2008
XLXR's Avatar
The platform of a floor jack may be unstable. The regular bike jacks are more stable.
