Last Post: lugster
0 Viking bags??
Last Post: cotton1
Last Post: Rico 05R
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
Last Post: jammantoo
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
0 Value of a Boattail?
Last Post: gravydog
5 Am I looking for Trouble ?
Old 18th May 2006
MakuaKane's Avatar
MakuaKane MakuaKane is offline
Sportster/Buell Model: 1200 Roadster
MakuaKane is on a distinguished roadMakuaKane is on a distinguished road
Default Should I wait??
Just wanted some advice from you "experts". I'll be getting my Ramflo 400 soon. Still saving up for the pipes, planning on Thunderheaders. Anyway, should I wait till I have both A/C and pipes before doing anything to my stock '06 1200R, or would it be OK to just do the A/C and rejet for now and install the pipes when I get them? Thanks for your input.
BTW, boy those dealers really push for the dynojet kits. The parts guy, ex-mech. here really flipped when he found out the mods I wanted to make (above), and wasn't going to use the kit (just rejet and adjust the idle mix). From all of what I've read so far here, Harley makes a good CV carb that only needs some minor adjustments. You'd think they'd stand behind their product better than that and not insist it needs something else....
"Nobody made a greater mistake than he who did nothing because he could only do a little."
- Edmond Burke
[URL="http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=4676"]View My Gallery[/URL]
[FONT="Palatino Linotype"]2006 Sportster Roadster (yellow pearl), Thunderheader, Forcewinder A/C, 48 slow jet w/2.5 turns out on the mix screw, 200 main jet, 1 brass shim under the needle, TwinTec tc88a igniton module and coil, Krankvents, ISO grips, and Progressive 412 shocks and fork springs, and a few other doo-dads.[/FONT]
Old 18th May 2006
torxster's Avatar
torxster torxster is offline
torxster is on a distinguished roadtorxster is on a distinguished roadtorxster is on a distinguished roadtorxster is on a distinguished road
My thinking would be it would most likely be OK to do the Ramflo now, but hold off on the jets till you get the new pipes. The AC just by itself without exhaust shouldn't warrant jets, it'll lean you out a little, but not much. Jets now would probably have you running too fat until you get the pipes on.
You'll definitely want to do the jets when the pipes go on.
I'm contrary 'cause I feel like it.
