Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 10th August 2008
orca2 orca2 is offline
Sportster/Buell Model: hugger 883/1200
orca2 is an unknown quantity at this point
Default Rust Removal
Ive Got Rust On My Headbolts . Can Someone Recommend A Good Product To Help.ive Tried Never Dull-never Worked! Thanks
stik7845 stik7845 is offline
Sportster/Buell Model: 1986 sportster
Sportster/Buell Year: 1986
stik7845 is an unknown quantity at this point
this may sound strange but easy-off oven cleaner works pretty good..but it's easier to get chrome covers from jp cycles..
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Gotta agree chrome covers are much easier. Try Naval Jelly if you really want to remove the rust. The problem is that most chemicals that will remove the rust will also remove the paint on the heads. Use sparingly and a little at a time until its all gone. Remember it'll probably show back up in a couple of months.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
ReddTigger's Avatar
Never Dull is NOT a rust remover.
Try using some toothpaste.. You'll be surprised..
also try some TACO BELL Mild sauce.. That stuff will clean a penny in a heartbeat.
States I've Ridden in
71.3 hp 70.8 tq
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Be careful with naval jelly it's an acid base product.Wash it right away with the garden hose and reapply if needed.
and to seal try clear finger nail polish that you can dilute 2 to 1.
In three words I can sum up everything I've learned about life: it goes on.
Deimus Deimus is offline
Master Bike Builder
It will be easier to put covers on the head bolts than to repair a blotch made to the heads. Something to think about.
Old 14th August 2008
Sporty47's Avatar
Sporty47 Sporty47 is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: 2006 Honda VTX 1300R
Sporty47 is on a distinguished roadSporty47 is on a distinguished road
forget the oven cleaner dude! The guy I bought my bike from read about using it on a forum and lets just say the result gave me a great bargaining point to bring the price down... looked like $&!%. I used a combination of Brasso to get the heaviest crud down then hours with Never-Dull. Redd-Trigger has a good suggestion. Toothepast and a good stiff bush. Its a mild abrassive and will take down the surface rust (with a lot of work... be patient) and it wont have bleed over affects on the heads. Get as much off as you can. Coat them with a protectant and put caps on them.
Motorcycle Mike
"I've come to like the taste of bugs over the years, but the hairy ones are still hard to swallow"! (me)
"...for those who man the battle line, the bugle whispers low, and freedom has a taste and price the protected never know..." (unknown)
"...The definition of tact is the ability to tell someone to go to hell and make them look forward to the trip..." (1SG Robert J. Nolan)
