Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 15th February 2005
johnboy johnboy is offline
Sportster/Buell Model: Sportster 883C
johnboy has disabled reputation
Default Where can I get a lower kickstand?
Have an 04 883C that has 11" progressive 412's, and will soon be installing the White Bros. fork lowering kit, which will lower the front end by 2". The bike has very little lean now, and I expect that it will be almost upright with the fork lowering kit installed. My HD dealer told me that I have the shortest kickstand for my bike, and I have been unable to locate one that is shorter. Can anyone recommend where I can get a lower kickstand and maybe provide me a part no. and size I might be looking for?
Moved On Moved On is offline
Did your dealer check the stand for the '05 L model? When they used to make Huggers the Hugger had a shorter stand AFAIK.
Gary
CuL8R CuL8R is offline
Sportster/Buell Model: XLH Hugger
CuL8R is an unknown quantity at this point
Agreed! I also own a Hugger and the stand is plenty lowe enough for what you are talking about. I am actually raising the front end of my bike with the installation of a brand new(never used) set of '00 1200s forks that I picked up dirt cheap! My Im still leaving the back low so my stand will still work for me.
Good luck!
Thing is a Hugger stand my not just bolt onto an '04??? But I'd be inclined to think that the '05 L would have a shorter stand like the Huggers did, and that ought to be bolt on compatible.
Gary
I believe the dealer looked at the 05 883L stand, but I will have to double check. It would certainly seem that L stand would work. In the event that these stands are not compatable for my bike, any other suggestions?
whiffy's Avatar
whiffy whiffy is offline
Riding with Angels
Sportster/Buell Model: Hugger
Other Motorcycle Model: Vincent
Other Motorcycle Year: 1951
whiffy is an unknown quantity at this point
Cut and weld!
Whiffi
Originally Posted by whiffy
Cut and weld!
Yep or just heat and bend.
Gary
whiffy's Avatar
Riding with Angels
Gary
That works too
Whiff
Old 17th February 2005
I was hoping to avoid any cutting and welding, but it is certainly an option I am considering.
slolane's Avatar
slolane slolane is offline
Sportster/Buell Model: XL883N
slolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of lightslolane is a glorious beacon of light
I have the HHI WideGlide 4 degree front end and 11" Progressive's in the rear so I also needed a lower stand. My local dealer ordered me one from a Hugger, it was $60. I hope this helps, James
Similar Threads
Lower Triple Tree Installation ? cantolina Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 10 28th January 2008 09:32
lower front...or not? engine Sportster Motorcycle General Discussion and Problems 15 30th April 2005 15:57
To lower or Not - Is my reasoning sound? Samueul Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 10 13th April 2005 01:49
Whats the Best way to lower a 2005 1200c Sporty gunlocators Sportster Motorcycle General Discussion and Problems 14 3rd March 2005 01:53
looking to lower my 05 1200c???help?? black051200 Rubber Mount Sportster Motorcycle Talk (2004-2006) 5 24th February 2005 00:50
