Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Tank swap
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Old 21st May 2006
sandy57 sandy57 is offline
Sportster/Buell Model: XL 883L
sandy57 has disabled reputation
Default HD Detachable windshield is too high???
Hey everyone, I just bought a HD detachable windshield, standard height off of ebay. It is about an inch to high for me seeing that I am only 5'1. Is there anyway to trim the windshield??? and How would I do that?
thanks.
2005 883L Sierra Red
cycle shack pipes
Stage 1
mustang solo seat
Solo rack
Old 21st May 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
Jig saw, then belt sander to smooth out the edges. Cover the shield with contact paper before starting to trim, and draw out the line where you plan on cutting first. It's not too bad.
--Chris
Old 21st May 2006
santansporty's Avatar
santansporty santansporty is offline
Sportster/Buell Model: XL883L
santansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enoughsantansporty will become famous soon enough
if you don't want to do it yourself, you could probably find a glass-cutter or windshield shop that would do it for you...
06 Black Heritage Softail
Old 23rd May 2006
Sporting Lad's Avatar
Sporting Lad Sporting Lad is offline
Sporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud of
"Measure twice, cut once." Use masking tape to experiment with where you'll cut. Apply a line of tape, then go for a ride. You only need to see about fifty feet ahead when looking overtop. Anything less could end up too short.
Unless you're really handy with tools, forget about DIY--windshields are expensive and you can ruin one very quickly and easily if you don't know what you're doing. The local dealership outsources these trim jobs. It ain't cheap, but it's worth it to end up with a good job.
Old 23rd May 2006
Mr Jimi's Avatar
Mr Jimi Mr Jimi is offline
Riding with Angels
Sportster/Buell Model: XL 1200 C Black & Silver
Mr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of light
thanks.
Sandy, Think about this? Its only 1 inch. Why take a chance on ruining a good W/S. there must be some adjustment in the mounting brackets? Look at it real good
Jim
my weather
home depot
A very touching video here
Making a F-550 Pick Up Thread
We are not near but we are close !
Amanda Overmyer Rocks !!
Dear Eliot
Eye Xray Here
Old 23rd May 2006
loki03xlh's Avatar
loki03xlh loki03xlh is offline
loki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to allloki03xlh is a name known to all
you could move the mounting brackets as far down on the froks as you can, and see if that helps.
Old 23rd May 2006
Deicer18's Avatar
Deicer18 Deicer18 is offline
Deicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura aboutDeicer18 has a spectacular aura about
I know you don't want to hear this option, but you can buy a compact lexan sheld rebuiild kit for $109 from Chicago Harley. It comes with the lexan, double sided tape, and rubber grommets. I don't know what the Part# is but you can get that from any dealer. List is $124.99 if I remember correctly. The rebulid is easy with the existing hardware that is on your present shield.
Old 23rd May 2006
Destry Destry is offline
Sportster/Buell Model: xl883
Destry has disabled reputation
This suggestion may be laughable, haven't finished my coffee yet so not fully awake...How about getting a beaded seat cover. Easy on and off. Will raise you up at least a half inch, and add great circulation for those hot summer rides. That plus a tweak in the mounting bracket position just might do the trick.
Old 23rd May 2006
chrishajer's Avatar
I second this sentiment. Of course, it negates the savings on the eBay windshield, but it's an easy solution.
--Chris
Old 23rd May 2006
cadiero's Avatar
cadiero cadiero is offline
Other Motorcycle Model: BMW R1200RT
cadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to behold
I would move the windshield down as much as possible. If the cutout for the headlight hits the headlight cut this section rather than the top of the windshield out. This will help cut down on wind coming up from under the windshield.
