0 900 dual carb front head
Last Post: thefrenchowl
0 Clutch issue
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 little rock
Last Post: tedg
0 New acquisition
0 brake lever for master cylinder.
0 Ignition question
Last Post: Anti-Hero
5 Summer time heat
0 79 Tranny
0 R.I.P. Arlen Ness
Last Post: oupa
Last Post: moparnut72
0 Have you taken your “dumbass pill” today?
0 883 to 1250 is done
0 883N brake/signal problem
0 I'm going nuts (Adjusting Fuel Mixture)
0 How long for the XL Member patch?
Last Post: bdawson
0 mid controls
Last Post: whetrick1
Last Post: farmall
Last Post: Lone Rider
0 Front cylinder noise
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
mike, Rick572 (72), Tailchaser (71), Back Road (55), sanman12002003 (54), LilMsRida (54), wargod1 (50), tplyons (32), DOM! (31)
Old 27th May 2006
dodgenbullets's Avatar
dodgenbullets dodgenbullets is offline
Sportster/Buell Year: 06
Other Motorcycle Model: yamaha wr426 offroad
dodgenbullets has disabled reputation
Default what's the float level specs for the CV40
What should the float level be set at in the CV 40 . More importantly, how do you measure it? My 06 1200r has been having fuel flow out the bowl vent hose. It's a problem that seems to come and go sporadicaly. I took the bowl off to check and clean the inlet needle. While the bowl was off, the carb was lets say "mishandled". I may have bent the tab on the float. It looks like it's hanging down farther now. I still got the carb off. I did a search on this first and found alot on the float and needle. I could not find specs or how to's on setting it. Does this help? Thanks,Dodgenbullets.
Old 27th May 2006
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Post
To measure you set the carb on the engine manifold side, then tilt it 15 to 20 degrees away from the float side until the float comes to rest. You have to measure from the carb flange face to the perimeter of the float. The manual says to use a vernier or dial caliper depth gauge. The measurement should be 0.413 - 0.453 in (10.49 - 11.51 mm). If it isn't, remove the float, bend the tab, reinstall the float, then measure again.
Folkie
South East England Riders
Old 27th May 2006
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
Remove carb, remove bowl, set level bottom side up. Measure distance between bowl mounting surface and bottom of float. Should measure between .725" and .730". That is for a 1988, so it may have changes since then.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
