0 Value of a Boattail?
Last Post: valvebeater
Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
Old 17th February 2005
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
Default Cam ID Question
Does anyone know what "Grind" the 1995 Buel Thunderbolt S2 stock cams are?
Will they fir a 2000 1200?
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
All S2's came with "D" cams, i.e. stock Sportster cams. The cams, if they're original, will be marked 1D, 2D, 3D, 4D.
In 2000, they changed the pitch on the pinion gear and the matching gear on the #2 cam. The new gear pitch eliminated the need to individually fit this connection for every motor. To put 91-99 cams into a 00-up motor requires either backdating the bike's pinion gear, or moving the drive gear from the original #2 cam to the new one.
In 2001, they went with this new gear pitch (aka "high contact ratio") on all the cam connections. So the process of fitting cams to the motor went away. But again, 91-99 cams can be installed in newer motors, and vice-versa, with the appropriate pinion gear.
A lot of really high performance cams (over .600 lift) are only available in the 91-99 gear cut. It's said to be stronger. I've never broken any of the new style though.
But anyway, if your 2000 model is a regular 1200, it already has the same cams as a Buell S2. The Sport model has "W" cams, as do the 04-up 1200's, but all other 91-05 Sportsters have "D" cams.
Buell S1's came out in '96 and had SE bolt-ins from the factory. S3's came out in '97, replacing the S2, and they also had SE bolt-ins for their entire production run, which went through 2002. X1's came out in '99, replacing the S1, and they had SE bolt-ins. M2's were made from 97-02 and they had "D" cams in the domestic bikes, SE bolt-ins in the international bikes. So if you're looking to pull some better cams out of a Buell and put them in your bike, think S1/S3/X1. 00-up cams will go right in, which limits you to X1's and S3's.
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
ASWR, when you say "bolt ins" are you refering to the .497 lift cams?
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
Old 18th February 2005
aswracing's Avatar
Yes. Aka Andrews N4's, same thing.
barry1967's Avatar
I did not know the SE497s were the same as N4s. Thanks
BunnMan's Avatar
BunnMan BunnMan is offline
BunnMan has disabled reputation
Default specs?
Any of you better informed folks have the specs on the W cams?
Thanks and God bless,
-BunnMan
barry1967's Avatar
W 08/26 I 234D 0.470L
W 36/14 E 230D 0.470L
Similar Threads
Ignition Module Question 0ut1aw Sportster Motorcycle Motor - Top End 13 12th April 2005 01:10
PISTON AND CYLINDER QUESTION LVBOATDOC Sportster Motorcycle Motor - Top End 16 9th March 2005 13:55
Cam choice question shooter Sportster Motorcycle Motor - Top End 3 31st January 2005 20:36
Stupid question about controls Mechano Sportster Motorcycle Motor - Top End 22 28th January 2005 00:37
