Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 4th June 2006
4-pac's Avatar
4-pac 4-pac is offline
4-pac will become famous soon enough4-pac will become famous soon enough4-pac will become famous soon enough4-pac will become famous soon enough4-pac will become famous soon enough4-pac will become famous soon enough4-pac will become famous soon enough
Thumbs up Don't forget your hose clamp for the Tax collector
Well I waited long enough, one week to be exact, before spending the evening in the garage to turn some wrenches on my new bike. I did the basic update with SE II slash cut slip-ons, SE-A/C, 185 main, 45 slow jet and idle mixture screw access. All-in-all it was an easy job and I learned a few things:
  1. If you plan to remove the carb for the first time, stop by an auto parts store and pick up a small hose clamp before you start. Nothing worse than having to leave a job to go get a part. Ask me how I know.
  2. The SE IIs may "slip-on" but the stock mufflers don't easily slip off! I eventually rotated the mufflers 90 deg counter clockwise (from the end view), disconnected the down pipe from the head, bolted the muffler back in place, and worked the pipe free.
  3. If you have an engine mounted horn, removing it will give a bit more slack with the enricher cable. This to help you get to the blasted nut that attaches the assembly to the carb. And rotating the carb with the inlet facing the ceiling will allow a wrench access from the bottom.
  4. RTFM on throttle cable adjustment. I was surprised how much difference turning the wheel lock to lock can make.
  5. Lastly, if you were a teenager when the first Star Wars movie was released, and you now spend your days at a desk, you might be amazed at the number of muscles that will ache the next day.
After 25 miles around the countryside, I'd have to say it was all well worth it. Great HD sound, smooth and powerful acceleration, and no popping through the carb. I'm lovin life!
Taxes Paid, hmmm what's next?
Old 16th June 2006
4-pac's Avatar
After a few days with the 185 main jet, it was apparent the bike was running too rich. The exhaust note was just not consistently smooth under a light load. Kinda like the sound you'd get going downhill backed off the throttle. So last Friday it was back to the 180 main jet. 250 miles over the weekend and I could tell it was a step in the right direction.
Fast forward another week. I decided to go down to a 175 main jet tonight and took her out for a 20 mile spin around the country. Seems to have smoothed out a bit more on the low load cruise. Next step, I think I'll try the recommended needle shims to work on the acceleration. Who knows, maybe a 170...
Totally OT. I've said it before: the folks at my dealer of choice, Smoky Mountain HD ROCK! I called up Eddie in parts to ask him about the 175 MJ. He went to check stock, came back and said they were out. Then he offered to go over to the dyno tune shop and rummage for one. After a few minutes on hold, he came back with a winner.
Terry
but my friends call me 4-pac
[URL="http://xlforum.net/forums/showthread.php?t=254258"]'06 Sportster 1200C w '07 EFI Conversion[/URL], SuperTrapp 2:2 exhaust and SE A/C
[URL="http://xlforum.net/forums/showthread.php?p=1494819#post1494819"]Click here for a review[/URL] of my $30 LoJack and GPS tracking powered by [URL="http://www.instamapper.com"]InstaMapper.com[/URL]
[inwindow=350]www.instamapper.com/ext?key=1009428850281076753&width=500&height=300&zoom=13&units=imperial&coords=d[/inwindow]
Old 3rd July 2006
dagsportster's Avatar
dagsportster dagsportster is offline
dagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the rough
Originally Posted by 4-pac
  1. If you plan to remove the carb for the first time...
  2. The SE IIs may "slip-on" but the stock mufflers don't easily slip off! ...
I drilled the mixture plug and did the lower carb work with the carb still attached and it was a piece of cake. Unless you're working on the upper carb, I don't see any reason to remove the carb, but that's my preference. Definitely replace those bowl screws with hex heads. I read here that 4mm x 16 was the recommended size, but I had to cut down two of them to keep them from scoring the carb body as they exited through the bowl.
For removing the stock mufflers, spray the joint with some WD40 and let it soak in. Then they'll REALLY slip off.
Just because you're a HOG doesn't mean you have to look like one!
Join the XLForum 2008 Weight Loss Challenge! (http://xlforum.net/forums/showthread.php?t=135254)
67 XL Forum members -- people just like you (only now a little skinnier) -- have joined and
pledged to lose over 2,400 pounds. We've lost over 459 pounds so far!
2 people have already achieved their goals!
Check out our progress on the Weight Loss Stats Page (http://homepage.mac.com/dagruber/.Public/XLFWeights.htm). You can join at any time by sending me a PM.
Check out my Sportster photo gallery (http://gallery.mac.com/dagruber#100025&view=carouseljs&sel=0)!
