Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Old 5th June 2006
XLFREAK XLFREAK is offline
Default Trailering your sporty..
Okay, I know, "ride the sucker"...but, I'm thinking ahead...to when the snow falls again....and I want to load the beast on a trailer...and head south.
I do have a trailer that should do the job....how best to tie the bike down?
What do you use for a trailer?
Old 5th June 2006
H@mbone!'s Avatar
H@mbone! H@mbone! is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1987
Other Motorcycle Model: Custom Shovelhead Softail
Other Motorcycle Year: 1971
H@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura about
Well I have been useing what looks like a utility trailer but hinges up. But I have my wife get on it and push the front forks down and I wrap a couple rachet straps around the handle bars and pull on them till there tight and rachet a way keeping both sides of the bike even. I strap the other end of the straps to the front of the trailer one at each corner. I usually try to get the forks as down as far as I can get them stopping at the bottom triple trees if I can. Then I run a strap thew the rear wheel from one side of the trailer to the other putting a little pull to the front of the trailer then strapping it down. Thats the best way I have found to hold my bike down.
71 HD Shovelhead in a aftermarket softail frame and 87 HD Sportster XLH883
Old 5th June 2006
Vegas1200C's Avatar
Vegas1200C Vegas1200C is offline
Vegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to all
You want to chock the wheels if you can. A good bump can slide the wheel sideways and then you are in trouble. DO NOT compress the forks all the way. Too much compression over a long period of time will blow your seals. Try to get ratchet straps across the front and back at a 45 degree angle. Do not strap to the handle bars. They aren't designed for that stress. Do not cover the bike. Any dirt on the cover or bike will scratch the paint.
Sold my 2004 Lava Red 1200 Custom, went darkside 2015 RGS
Old 5th June 2006
OldFenderGuy's Avatar
OldFenderGuy OldFenderGuy is offline
Other Motorcycle Model: Dyna WideGlide
Other Motorcycle Year: 1996
OldFenderGuy is an unknown quantity at this point
I use one of the "Bike-Grabs", that are heavy duty steel, and by themselves will hold your bike in place.
Has a quick disconnect trailer mount, so it only takes about 30 seconds to put in a trailer for trailering a bike, or to use it on it's own to hold the bike level for general maintenance, etc. (See below picture)
To trailer a bike, just ride the bike into the chock, which holds it upright and level. Couple of straps and you are good to go.
[i]2005 Sportster 1200C - Lava Red Sunglo
1996 WideGlide (FXDWG) - Metallic Lava Red
2003 Anniversity FatBoy - EFI, SERT, Dyno Tuned
1981 "Sturgis" Shovelhead (Semi Retired)
1949 Panhead Custom Chopper (More Than Semi Retired)[/i]
Old 5th June 2006
mikeLI_77's Avatar
The above way is good, just a few add ons or alternatives to it. If you have a solid rear wheel you could put a strap between the tank and seat on the frame of the bike, you just don't want to angle them to far back so the strap is rubbing against the battery cover and oil tank. That's how I strapped mine down once and it worked fine. Put some rags between the strap and whatever area you attach the straps down. If you have a spoked rear wheel try and put the strap on the rim itself and try not to let the strap pull on the spokes when you strap it down. If you use brand new straps check them after a few miles of towing it because new straps may stretch a bit and you don't want them to get too loose.
2002 XL1200C (originally)
Supertrapp supermeg exhaust 20 disks and open end cap, S&S roller rockers, Alto Carbonite clutch with Energy One 15% heavier spring plate, Daytona twin tech single fire ignition 1005s
Ricor intimnators, 13" Ricor IAS shocks, Brembo dual disk setup from a 2012 street glide with matching brembo street glide master cylinder,
States I Have rode through
Old 5th June 2006
Snuffy's Avatar
Snuffy Snuffy is offline
Sportster/Buell Model: 04R
Snuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the roughSnuffy is a jewel in the rough
Use a Pingle front chock on mine, compress the front shocks about 1/3 and rachet to keep bike plumb or straight up and down. I stap at the top of the tree on a 45 degree angle and a strap through the front wheel, just enough tension to keep bike from shifting. Do not leave bike in gear. I also strap each back shock on a 45 degree with the straps pulling forward towards the tongue of the trailer. I put a tension on the back shocks. Do not compress front forks or back shocks to their limit just enough on the back like you were sitting on it. Trailered mine from Tennessee to Texas with no problems. one more thing remember to secure the loose end of the tie down. don't want them flopping in the breeze and smacking your scooter. Put the rachet as close to the floor as possible
Old 5th June 2006
snowman's Avatar
snowman snowman is offline
OFG - Where did you grab this bad boy?????
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 5th June 2006
I found out about them from some guys I know that used them while at Bike Shows.
They are great, both for trailering and also for doing regular work on your bike when you want it to be sitting level.
They are adjustable and work on front or rear wheels from 80mm to 210mm.
Here is more information and a review by webBikeWorld;
http://www.webbikeworld.com/motorcycle-wheel-chock/
More information from a firm that sells them;
http://www.lockitt.com/BikeStands1.htm
Old 6th June 2006
XL O.C.D.'s Avatar
XL O.C.D. XL O.C.D. is offline
Other Motorcycle Model: Mustang GT
XL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura aboutXL O.C.D. has a spectacular aura about
Wheel Chock!!!! Trust me. I was driving on an unfamiliar road this weekend, 60 mph in the middle of nowhere following a jacked up SUV. SUV hit the railroad tracks at 60, I hit the brakes and by the time the trailer hit the tracks I was still doing 35... bounce... my heart sunk faster than the bike dropped when I saw the headlight disappear from my rearview mirror.
One of the straps pulled the front end sideways over the bump.
I won't be trailering again without a Wheel Chock!!!
Old 6th June 2006
Mr Jimi's Avatar
Mr Jimi Mr Jimi is offline
Riding with Angels
Sportster/Buell Model: XL 1200 C Black & Silver
Mr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of lightMr Jimi is a glorious beacon of light
All real good suggestions! I agree with all of them and I always use 4 ratcheting straps and at 45 degree angles and it will stay where ya put it. Don't forget a stone shield of some sort to keep rocks and dirt from hitting your bike, kinda like a wind deflector? Then what are ya gonna do at a motel? Bike thieves love bikes already on trailers Here is a picture of the way we carry ours?
Its our camper also
Jim
my weather
home depot
A very touching video here
Making a F-550 Pick Up Thread
We are not near but we are close !
Amanda Overmyer Rocks !!
Dear Eliot
Eye Xray Here
