0 strange small wires attached to coil
0 24633-77 Breather assembly
Last Post: ericfreeman
5 Transmission HELP!
Last Post: Twistedrench
0 Sportster or Street Bob
Last Post: Baby883
0 Ei
Last Post: tvon
0 Solar battery charging
Last Post: tvon
Last Post: wachuko
0 primary chain temp.
0 2016 48 Hesitating
Last Post: XLXR
Last Post: prahxy
Last Post: hhugger
Old 12th June 2006
Gone Gone is offline
Default left rear turn signal replacement
I need to replace the left rear turn signal assembly on a 01 hugger. Any suggestions or directions on the best way of to do this would be greatly appreciated. Thanks Allen
Old 12th June 2006
Vegas1200C's Avatar
Vegas1200C Vegas1200C is offline
Vegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to allVegas1200C is a name known to all
Not sure about the 01 but the newer bikes have the electrical connection inside the tail light. Pull the cover off the taillight. Disconnect the little plug. Mine wouldn't fit through the strut so the plug had to be disasembled.
Sold my 2004 Lava Red 1200 Custom, went darkside 2015 RGS
Old 12th June 2006
thanks for the info.
Old 29th September 2006
Dave downunder's Avatar
Dave downunder Dave downunder is offline
Dave downunder is an unknown quantity at this point
Default I need help too.
I also need to replace my left hand back turn signal. I've got the factory workshop manual but cannot see any instruction for how to do this. I understand that I need to remove the end connector plug to get the cable through the fender. What I cannot work out is the clip inside the fender, next to the turn signal arm bolt, that the cable is under. It's really in their tight. How is this clip retained to the fender? Do I use force to get the old cable out and new back in?
Next challenge will be getting the new cable cable ends into the terminal connection. I have new pins ready to go.
Thanks in advance. Dave.
Moved On Moved On is offline
The metal clips on the inside veritcal edges of the fender are pop riveted on. You should be able to bend them up a bit to get the wires loose.
Gazza
Thanks Gazza, I wish the workshop manual showed the removal and install of these things.
Have a top week-end, Dave 2001 XLH1200
Old 8th August 2009
Bedrock Bedrock is offline
Sportster/Buell Model: 883 standard
Bedrock is an unknown quantity at this point
Thats it, so no one really knows how to get the assem off?
Old 8th August 2009
derailedbus's Avatar
derailedbus derailedbus is offline
Sportster/Buell Model: xl 1200s
derailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to allderailedbus is a name known to all
Nope. Nobody's ever replaced their signals on here. As stated above, plug is in brakelight housing. Biggest problem I had was getting the pins out of the harness, but it's a cinch after watching someone who knows what they were doing do it. Nut on stud inside fender holds stem and signal housing on.
