0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 19th February 2005
kjbsporty's Avatar
kjbsporty kjbsporty is offline
Sportster/Buell Year: 02
kjbsporty is an unknown quantity at this point
Default Broken Belt
I just got done warming my bike up. It was great to hear it run and sit on her and think about riding. I would have gone for a ride but I need a new belt. So here is the question. Has anyone broke a belt? I have broke THREE ! The first one was at 40,000. I am not sure if that was wear, loose belt or a combination. It did not show much wear and I was getting on it when it broke. I did not replace the pulley even though I was told it should be when a belt brakes. It didn't look that bad. The next one was at 46,000 miles. This one was probably the pulley. The belt shows no wear on the outside edges. They snap straight across. This last time was at 64,000 miles. I am now replacing the pulley also. The chrome is chipped off on the majority of the teeth. What kind of milage is everyone getting? Harley stealers have told me 40k-50k miles. I know some people with 65k-80k on an original belt.
Thanks
Kevin
Mine broke at around 20,000 miles. There was a thread on this topic on the old XL forum. You might try a search there.
Old 20th February 2005
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
Probably depends how you ride. If you do a lot of burn outs and wheelies and flog it a lot probably pretty hard on the belt. If you're a mild mannered commuter, probably get a lot more life out of one.
If you hate me, I've probably given you just cause. There, feel better?
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
Check your belt tension...
having it too tight will reduce the life of the belt...
How they are used seems to have little affect....
My first one lasted 40,000 HARD kays and snapped on a first/second gear change at the strip....
The second had another 42,000+k's and was fine when I pulled the bike down....
The second one was still fine
I know customers that are getting up near 100,000 kays and others that are lucky to get 20,000 ....ridin the same sort of rides..
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
I've heard som scuttle about the pulley teeth. Seems like they sometimes wear sharp enough to cut thru the belt.
What anyone else thinks of me is none of my business.
Similar Threads
Belt Adjustment on 05 custom 883 custom Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 11 30th April 2012 21:29
Broke Another Belt! Help w/ Belt to Chain Conversion HD1200R Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 11 2nd June 2005 12:21
Belt Chirp eskiv Rubber Mount Sportster Motorcycle Talk (2004-2006) 19 28th April 2005 15:36
Belt Adjustment ?'s chipdog4 Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 5 19th April 2005 03:55
chaincase/tranny fluid and final belt questions Alasportster Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 8 26th March 2005 15:23
