0 Paulie420 needs your help.
Last Post: Jowniofownio
0 Not charging issue!
0 Value of a Boattail?
Last Post: Moon Wolf
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
Old 5th September 2008
RcRacer's Avatar
RcRacer RcRacer is offline
Sportster/Buell Year: 1981
RcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura about
Default Fixed the clunky front caliper noise ....
Thanks to a few posts I found in these forums, I tried a solution based the posts. After a week of commuting to work, I can tell you - It works!
Ever since I put the bike together from a frame off rebuild, I have had a very audible clunk in the front calipers as I grab the front brake lever. When I grab the brake very lightly, sometimes it would rattle and then stop as I put more pressure on the brake. The first time I heard it, it scare dthe $h1t out of me but eventually I discovered where the noise was coming from and could even see the caliper movement and the corresponding "clunk" when I rocked the bike at a stop light.
Here's what I did. I removed the calipers and checked the bolts and lower fork bushings. The bolts were slightly worn but the bushings were fine. The holes in th calipers had a little more play than the bushings and probably contibute to most of the movement of the caliper. I installed the calipers with new bolts but I added a small piece of weather stripping between fork and the caliper at the top bolt. ( Glued to the fork ) There is just enough pressure there to dampen the movement but it is still free to move as designed.
The result is quite front brakes! Hopefully, if any of you have the same problem, you can use this simple fix to reduce the noise from the caliper.
boilermaker's Avatar
boilermaker boilermaker is offline
Sportster/Buell Model: 81 sporty
boilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really nice
Yup done that to both frt and rear Calipers on my 81 Just have to replace the stripping every once and a while after it packs down abit.
sesenta y ocho
part number 44125-82, foam tape, used on 1982, 1983 XL, XLS, XLX
